- To:
- Subject: Re: [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3 failed
- Date: Mon, 30 Mar 2009 23:51:00 +0200
- Importance: Normal
- Sensitivity:
Hi Joe,
your model features two empty triangles, i.e., the defining points are colinear. It's the following lines:
3 19 17 18
3 30 32 31
I attached a Nef file that is consistent, but you probably want to fix your off-file, too.
Peter
-----Joe C <> wrote: -----your model features two empty triangles, i.e., the defining points are colinear. It's the following lines:
3 19 17 18
3 30 32 31
Peter
To:
Date: 03/28/2009 12:02AM
Subject: [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3 failed
Hi,
I was converting a polyhedron (see attached Polyhedron.off) to Nef_polyhedron_3, but it failed. I checked my polyhedron, it is closed and valid. The kernel used is Exact_predicates_exact_constructions_kernel. Does anyone have idea why the conversion failed? Is there any way to catch the failure and avoid crashing the program?
Thanks.
Joe
[attachment "Polyhedron.off" removed by Peter Hachenberger]
Polyhedron.nef3
Description: Binary data
- [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3 failed, Joe C, 03/28/2009
- [cgal-discuss] Re: Conversion from Polyhedron_3 to Nef_polyhedron_3 failed, Joe C, 03/30/2009
- Re: [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3 failed, Peter Hachenberger, 03/30/2009
- Re: [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3, Joe C, 03/31/2009
- Re: [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3, Laurent Rineau (GeometryFactory), 03/31/2009
- [cgal-discuss] Site_2 constructor?, Khuong Vu, 03/31/2009
