cgal-discuss - Re: [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3
  • To:
  • Subject: Re: [cgal-discuss] Conversion from Polyhedron_3 to Nef_polyhedron_3
  • Date: Mon, 30 Mar 2009 23:42:23 +0100
On Tuesday 31 March 2009 00:26:37 Joe C wrote:
> Thanks, Peter. I also found that there are two degenerated triangles for my
> input data. So I guess CGAL's polyhedron_3 still considers this as closed
> and valid even though it has degeneated cases. I suggest that the two
> methods : is_close() or is_valid() return false with some error message so
> the user is aware that the polyhedron with degenerated triangles is not
> allowed to converted to Nef_polyhedron.
Polyhedron_3 and Nef_polyhedron_3 are two different packages. I do not see why the is_valid() function of Polyhedron_3 should be aware of the prerequisites of a function of Nef_polyhedron_3.
That said, there should be a function in Nef_polyhedron_3 that helps users to check prerequisites of a conversion from a Polyhedron_3. The Polyhedron_3::is_closed() is not sufficient.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
