- To:
- Subject: Re: [cgal-discuss] Where is the Ridges Viewer ?
- Date: Tue, 7 Apr 2009 14:24:04 +0200
Hi,
sorry for the inconvenience, but this viewer no longer exists, you'll have to use your favorite one to display the appropriate info from the data.
BEst,
Marc
On 06 , Apr , 2009, at 11:58 , <> <> wrote:
Hi,
I compiled CGAL 3.3.1 from the sources (on MacOS X Leopard) and the example to
extract ridges on a polyhedron and in the README it is explained that the
ridges_viewer may be used to view the ridges :
Program Compute_Ridges_Umbilics
takes a polyhedron (filename.off file) as input,
it computes a jet fitting to set the monge data at each vertex
computes the ridge lines and the umbilics
it outputs the results in :
1. filename.offRIDGES-d?-m?-t?-a?-p?.4ogl.txt which can be visualized with
the demo program ridges_viewer.exe
EXAMPLES
./Compute_Ridges_Umbilics -f data/poly2x^2+y^2-0.062500.off -d4 -m4 -a4 -t3 -v0
visu with:
../../demo/Ridges_3/ridges_viewer data/poly2x^2+y^2-0.062500.off
data/data_poly2x^2+y^2-0.062500.offRIDGES-d4-m4-t3-a4-p0.4ogl.txt 0 0
(Taken from the README file)
Unfortunately, I did not find this program and there is no source code to
create it... How can I visualize the ridges on my mesh ?
Thanks in advance.
- Re: [cgal-discuss] Where is the Ridges Viewer ?, Marc Pouget, 04/07/2009
