cgal-discuss - Re: [cgal-discuss] Halfedge_around_vertex_circulator
  • To:
  • Subject: Re: [cgal-discuss] Halfedge_around_vertex_circulator
  • Date: Tue, 7 Apr 2009 22:32:50 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=WLXkczDIfXgsEvg9cU/TO9tR1aB47pSUPkH8pcoCachU6Pr9RUcW6ckV05dXQsq8qu POZUhen5jPcnuYxUuDBef7rG13sd0OMTxVZTzbN5MgpSlJwaPs8a6fwFFKZgy1js+FuQ itGwzZtKtc40Q1qZnMDlWcXONvHrwHVNR7jh4=
according to the documentation it seems to be the case :
"The polyhedral surface provides convenient circulators for the
counterclockwise circular sequence of halfedges around a facet and the
clockwise circular sequence of halfedges around a vertex."
( found on page
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Polyhedron/Chapter_main.html
section 21.3.6 ).
If you don't trust it, you can still implement it by successions of
next()->opposite() operations, I guess.
Ben
On Thu, Apr 2, 2009 at 9:07 PM, Priyamvad Deshmukh
wrote:
> I need to calculate the angle defect at each vertex of a polyhedron.
> Will the Hafedge_around_vertex_circulator always give me halfedges in a
> sequence? For example can two consecutive edges returned from the circulator
> be used to calculate the angle defect?
> Priyamvad
