- To:
- Subject: [cgal-discuss] Error converting back to double...
- Date: Tue, 14 Apr 2009 21:23:17 -0400
Hi Y'all,
I am using a kernel based on
Simple_cartesian<lazy_exact_nt<Quotient<MP_Float> > >
I make an exact-predicates triangulation where every finite vertex is inside an axis-aligned bounding box with integer corners.
Here's the part I don't understand:
- If I compare every vertex to this bounding box (promoting the bounding box from double to my kernel numeric type) every point is within or on the box.
- If I convert my coordinates to_double, those doubles sometimes are outside the box by rounding error.
What's particularly weird is that
- CGAL tells me that the points that "go outside" the box are EXACTLY on the AABB edge and
- Since the AABB edge is "integral" (e.g. -117.0, 34.0 -> -116.0, 35.0) they should be exactly representable in a IEEE double.
I see from the manual that to_double is an approximation...what is the right way to get a conversion back to double that will be exact when exactness is possible?
cheers
ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Error converting back to double..., Ben Supnik, 04/15/2009
