- To:
- Subject: Re: [cgal-discuss] Getting different results...
- Date: Thu, 16 Apr 2009 09:26:56 +0200
Benjamin schwarz wrote:
Hello Monique,
In 2D the result may depend on the order in which your algorithm is adding
new points, in case of co-circular points.
Is this a specificity of the 2D case ? I mean, I thougth that for
3D Delaunay triangulations, the triangulation would be the same
whatever the order in which points are inserted (due to the use of an
"emulated alphabetical reordering" of points used for the symbolic
perturbation).
Hi Benjamin,
You are right. The symbolic perturbation is not the same in 3D. In 3D it is independent of the order of points, it uses a lexicographical comparison on the coordinates of the points.
Best regards,
Monique
- [cgal-discuss] Getting different results..., (continued)
- [cgal-discuss] Getting different results..., panayiotis foteinos, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Damian Sheehy, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Andreas Fabri, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Monique Teillaud, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Andreas Fabri, 04/16/2009
- Re: [cgal-discuss] Getting different results..., panayiotis foteinos, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Benjamin schwarz, 04/15/2009
- Re: [cgal-discuss] Getting different results..., Monique Teillaud, 04/16/2009
