- To:
- Subject: Re: [cgal-discuss] removing triangle face
- Date: Wed, 15 Apr 2009 16:35:39 -0400
Hrm - I think that the triangulation has to cover an infinite plane (between finite faces and infinite faces). So you can't have a "hole" in the triangle mesh. (That was my understanding back in CGAL 3.0 at least. :-) You could attach a flag to your face data, allowing you to skip marked faces during iteration later.
The newer meshing data types may be better for removing "pars" of a mesh.
cheers
ben
skific wrote:
Hi,
I'm using CGAL::Delaunay_triangulation_2<Traits,Tds> to generate triangulation
mesh. I'd like to remove triangle faces based on predefined criteria, say I'd like to
remove triangles that are too "narrow" - one of three angles is say smaller
than 10°.
Is there a way to remove triangles (their faces) from the mesh, but without
removing vertices?
best regards,
skific-- You are currently subscribed to cgal-discuss.
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] removing triangle face, skific, 04/15/2009
- Re: [cgal-discuss] removing triangle face, Ben Supnik, 04/15/2009
- Re: [cgal-discuss] removing triangle face, Andreas Fabri, 04/15/2009
- Re: Re: [cgal-discuss] removing triangle face, skific, 04/16/2009
- Re: [cgal-discuss] removing triangle face, Laurent Rineau (GeometryFactory), 04/15/2009
