- To:
- Subject: Re: [cgal-discuss] removing triangle face
- Date: Wed, 15 Apr 2009 22:37:59 +0200
skific wrote:
Hi,
I'm using CGAL::Delaunay_triangulation_2<Traits,Tds> to generate triangulation
mesh. I'd like to remove triangle faces based on predefined criteria, say I'd like to
remove triangles that are too "narrow" - one of three angles is say smaller
than 10°.
Is there a way to remove triangles (their faces) from the mesh, but without
removing vertices?
best regards,
skific-- You are currently subscribed to cgal-discuss.
You should use a Triangulation_face_base_with_info_2
and just mark your face that you want to give it a special
treatment.
andreas
- [cgal-discuss] removing triangle face, skific, 04/15/2009
- Re: [cgal-discuss] removing triangle face, Ben Supnik, 04/15/2009
- Re: [cgal-discuss] removing triangle face, Andreas Fabri, 04/15/2009
- Re: Re: [cgal-discuss] removing triangle face, skific, 04/16/2009
- Re: [cgal-discuss] removing triangle face, Laurent Rineau (GeometryFactory), 04/15/2009
