cgal-discuss - Re: [cgal-discuss]  CGAL 3.4 - Simple program not comp iles
  • To:
  • Subject: Re: [cgal-discuss]  CGAL 3.4 - Simple program not comp iles
  • Date: Thu, 16 Apr 2009 11:11:41 +0200
  • Importance: Normal
  • Sensitivity:
That's because you use gmpq with Extended_homogeneous. This kernel expects
an integral number type like gmpz.
Peter
-----"Max" <> wrote: -----
To: <>
Date: 04/03/2009 05:09AM
Subject: [cgal-discuss] CGAL 3.4 - Simple program not compiles
Hello,
The following simple program does not compile. I'm using VC2008SP1
under WinXP/SP1.
#include <CGAL/Extended_homogeneous.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Nef_polyhedron_3.h>
typedef CGAL::Extended_homogeneous<CGAL::Gmpq> Kernel;
typedef CGAL::Nef_polyhedron_3<Kernel>     Nef_polyhedron_3;
typedef CGAL::Plane_3<Kernel>     Plane_3;
int _tmain(int argc, _TCHAR* argv[])
     Nef_polyhedron_3 N;          // w/o this line, it compiles well
       return 0;
Thanks for any help.
B/Rgds
Max
