cgal-discuss - [cgal-discuss] CGAL and Java
  • To:
  • Subject: [cgal-discuss] CGAL and Java
  • Date: Wed, 22 Apr 2009 13:21:59 +0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=LJIvL7lNTZn8+yyLddSfPsVelSwvWuSmCq95AIxT20Bj+Xk0YC7vqVNcf1rV2HmX9d hhqattcUmmEyusISSkVwfByhbP5uBZXa7dtstKqbcikW7barI7zoSwrkGRsuzDE5qfKH bVL+vj32xEGwl6FMPUNFkIAfmjqQEOjbNTgZk=
Hello Everyone
                    This is my first post in the forum. I am trying to use CGAL in Java to solve Appolonius circle (Venori Diagram). I would be grateful if anyone can point out any tutorial or a jump start help.
Thanks for any help you can provide
On Wed, Apr 22, 2009 at 1:11 PM, Laurent Rineau (GeometryFactory) <> wrote:
On Monday 20 April 2009 10:08:56 Laurent Rineau (GeometryFactory) wrote:
> On Monday 20 April 2009 04:03:18 wrote:
> > Hi all, I'm having issues with passing cgal objects and variables, ie
> > when a valid face_handle is passed to a different function it suddenly
> > changes all its values etc
> > Face_handle current = surface[i], test =
> > surface[i]->neighbor(j);//current and test are both fine
> > CheckWall(current, test, &hazardType, &tested, &numTested);//inside
> > CheckWall() their values are completely different
> If your function CheckWall modifies the triangulation, handles to faces
> may be modified (like iterators of a vector when you insert things in it).
On Wednesday 22 April 2009 01:38:51 Haz wrote:
> No the function didn't modify the triangulation in any way, it was just
> comparing triangles and their relative angles/orientation and I commented
> out everything but one line (so the debugger would have something to stop
> on) and still same weird issue. Simply passing the face_handle seems to
> screw it up, with using pointers being the only way I found to not have it
> change.
In that case, the behavior of your code is strange. You should give us a small
compilable code that shows that behavior, as well as the usual information:
 - OS
 - compiler, and compiler version
 - CGAL version used,
 - boost version used.
See http://www.cgal.org/bug_report.html
I reply below to another point of your first post in the current discussion...
> I've also had problems with things as simple as integers, having to use the
> following code -
> int x = coord->x(), y = coord->y(), z = coord->z();
> fprintf(output, "%d %d %d\t", x,y,z);
> as opposed to - fprintf(output, "%d %d %d\t",  coord->x(), coord->y(),z
> coord->z());
> or else the numbers printed are random gibberish.
You do not give us enough information! What is "coord"?! I imagine that is a
Kernel::Point_3 for a given kernel. Which kernel did you us? I doubt coord-
>x() is an int! Maybe it is a number type that can be converted to int, but I
am not surprised that printf does strange things with such a type. Do the cast
yourself:
 printf(output, "%d %d %d\t", (int) coord->x(),
                              (int) coord->y(),
                              (int) coord->z());
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
Regards
      Lonex
  • [cgal-discuss] CGAL and Java, Qasim Lone, 04/22/2009
