cgal-discuss - Re: [cgal-discuss] Using finger search with Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Using finger search with Delaunay Triangulation
  • Date: Wed, 22 Apr 2009 12:28:37 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=jtPP4LKrBMIZ+wltL4DN5HU5pd0uvdeltmgwOETF99dAUWkp4WhFVQM9OaiSq0Iyvw XfZjSHJadNYAoFlHZ5v2eI7pVclSKSO/lThTAxQeuhDFxxovEu6cTVswKYSSwjmvH7ta pbD1Kyj/lDcA6VY+g1eVVnHT2c1fsCWVQ6skQ=
Sylvain,
thanks for your answer. However, please have another look at the data
(I cut out the lesse interesting columns so the table is not wrapped.
Note that I am also performing a query without hints. In this case, I
would expect the delaunay hierarchy to be faster than the delaunay
triangulation.
Could someone compile the source file (reattached in this email) and
verify my results?
Somehow, I have the impression that the same code is called for the
delaunay triangulation and the delaunay hierarchy.
Bests,
Manuel
n dt_no_finger dt_finger dh_no_finger dh_finger
2 0.505304 0.477886 0.475679 0.475234
4 0.103188 0.102858 0.102885 0.101524
8 0.042936 0.041076 0.043392 0.041294
16 0.056725 0.047944 0.056533 0.048035
32 0.075375 0.059116 0.075654 0.059563
64 0.088672 0.062105 0.088614 0.062050
128 0.132514 0.086989 0.132462 0.087279
256 0.140531 0.078194 0.140511 0.078217
512 0.175971 0.064753 0.173778 0.064725
1024 0.222064 0.069129 0.221879 0.069079
2048 0.299477 0.067341 0.298769 0.067386
4096 0.392608 0.066532 0.393548 0.066462
8192 0.547986 0.069801 0.546512 0.069839
16384 0.741440 0.066260 0.741307 0.066181
32768 1.080815 0.067014 1.084949 0.066969
65536 1.518390 0.066989 1.512893 0.067106
131072 2.312096 0.070554 2.320022 0.071241
262144 3.690626 0.072124 3.677720 0.071980
524288 6.416665 0.072153 6.279038 0.071597
1048576 13.649976 0.072951 13.965254 0.074540
2097152 27.961286 0.075513 27.911974 0.075280
4194304 48.720407 0.079028 49.280193 0.078284
-- Manuel
2009/4/20 Damian Sheehy
> Sylvain,
> Thank you for enlightening me!  :)
> Manuel,
> Your non-hierarchical triangulation (dt_build in your notation) calls the
> dt.insert(begin, end) interface. This interface performs preprocessing to
> sort the points along a Hilbert curve which improves the performance of
> insertion. I did not factor this in when I compared computation times for
> the Delaunay and the Delaunay+hierarchy construction. To perform an
> apple-to-apple comparison of the performance of these two algorithms you
> should use the dt/dh.insert(Point) interface.
> So in summary, the hierarchy is not being leveraged during construction
> because the sort ensures the resulting sequence of points is in close
> geometric proximity; the hierarchy is not being leveraged during
> nearest_vertex queries because you are already providing a good starting
> hint. Conclusion, the hierarchy is not doing anything for you so you don't
> need it.
> Best regards,
> Damian
> On Sun, Apr 19, 2009 at 8:10 AM, Sylvain Pion
> wrote:
>> Hi Damian,
>> Damian Sheehy a écrit :
>>> For a random set of points the Delaunay hierarchy should build a
>>> triangulation in much less time than the conventional Delaunay without a
>>> hierarchy. The numbers do not reflect that, so something is wrong. I will
>>> run your example tomorrow and see what I get. . .
>> This is not true anymore in recent CGAL releases, more precisely
>> since the introduction of a spatial sorting preprocessing phase (BRIO).
>> Sylvain Pion
>> INRIA Sophia-Antipolis
>> Geometrica Project-Team
>> CGAL, http://cgal.org/
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
// File: test_dh_finger.cpp
// Author: Manuel Holtgrewe
#include <tr1/random>
#include <vector>
#include <CGAL/Circle_2.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_hierarchy_2.h>
#include <CGAL/Real_timer.h>
// The Kernel we will use in our datastructures.
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
// Define some geometric primitive types.
typedef K::Circle_2 Circle;
typedef K::Vector_2 Vector;
// The datastructures for the Delaunay triangulation hierarchy.
typedef CGAL::Triangulation_vertex_base_2<K> Vbb;
typedef CGAL::Triangulation_hierarchy_vertex_base_2<Vbb> Vb;
typedef CGAL::Triangulation_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K, Tds> Dt;
typedef CGAL::Triangulation_hierarchy_2<Dt>
Triangulation_hierarchy;
typedef Triangulation_hierarchy::Vertex_circulator
Vertex_circulator_hierarchy;
typedef Triangulation_hierarchy::Point Point;
typedef Triangulation_hierarchy::Vertex Vertex;
typedef Triangulation_hierarchy::Vertex_handle Vertex_handle;
typedef Triangulation_hierarchy::Face_handle Face_handle;
const int seed = 42;
int main(int argc, char **argv)
std::tr1::mt19937 mt(seed);
int m = 1 << 16; // Number of queries.
printf("Delaunay Hierarchy: finger query vs. non-finger query\n");
printf("%10s %14s %14s %14s %14s %14s %14s %14s %14s\n", "n", "dt_build",
"dt_no_finger", "dt_finger", "dt_speedup", "dh_build",
"dh_no_finger", "dh_finger", "dh_speedup");
// Create the queries on a line (0, 0) to (1, 1).
std::vector<Point> queries;
for (int i = 0; i < m; ++i) {
double x = 1.0 * i / (m - 1);
queries.push_back(Point(x, x));
for (int k = 1; k <= 23; ++k) {
int n = 1 << k; // number of points
printf("%10d", n);
// Create points.
std::vector<Point> points;
for (int i = 0; i < n; ++i)
points.push_back(Point(1.0 * mt() / mt.max(), 1.0 * mt() / mt.max()));
// Delaunay triangulation.
Dt dt;
// Insert points into Delaunay triangulation.
CGAL::Real_timer timer;
timer.start();
dt.insert(points.begin(), points.end());
timer.stop();
printf(" %14f", timer.time());
// Perform queries without finger.
double no_finger_time;
timer.start();
for (int j = 0, jend = queries.size(); j < jend; ++j)
dt.nearest_vertex(queries[j]);
timer.stop();
no_finger_time = timer.time();
// Perform queries with finger.
double finger_time;
timer.start();
Vertex_handle v = dt.nearest_vertex(queries[0]);
Face_handle f = v->face();
for (int j = 1, jend = queries.size(); j < jend; ++j) {
v = dt.nearest_vertex(queries[j], f);
f = v->face();
timer.stop();
printf(" %14f", no_finger_time / finger_time);
// Delaunay hierarchy.
Triangulation_hierarchy dh;
// Insert points into Delaunay hierarchy.
timer.start();
dh.insert(points.begin(), points.end());
timer.stop();
timer.start();
dh.nearest_vertex(queries[j]);
timer.stop();
double finger_time;
timer.start();
Vertex_handle v = dh.nearest_vertex(queries[0]);
v = dh.nearest_vertex(queries[j], f);
f = v->face();
timer.stop();
printf("\n");
return 0;
