cgal-discuss - Re: [cgal-discuss] power diagram of a set of 3D weighted points
  • To:
  • Subject: Re: [cgal-discuss] power diagram of a set of 3D weighted points
  • Date: Sun, 26 Apr 2009 17:18:21 +0000 (GMT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.it; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=Hhaf6j4imrJmbJ5/a0g6zlhtN7VxfYiDvCfNkqYncMzI3dvAJQ4CLJ3NKRdZwqqHelDzWs1LIQVVmOmv2r7CP29ZhO4l0IUoHRYS2MDxY6kz6hpdTuSt96wbeksoxVTXKFSDVGJNKUB+endNfqUG/y9/50ESm01u7HLbRai3ESM=;
Dear Monique,
i have just read the chapter dealing with the regular triangulation,indeed i'm able to improve it for my set of spheres,but i don't know how i have to do to traverse it for each sphere as well as to improve the power diagram.
You can help me?
Cheers,
Francesco Perrone
Da: Monique Teillaud <>
A:
Inviato: Domenica 26 aprile 2009, 18:17:25
Oggetto: Re: [cgal-discuss] power diagram of a set of 3D weighted points
Hi
Have you read the chapter "3D triangulation" in the CGAL manual?
best,
    Monique Teillaud
perrone wrote:
> I'm an italian student of Salento University (Lecce,Italy) and in my mechanical
> engineering degree thesis i want to make a model of an aluminium open cell foam
> using laguerre tessellation.
> Some applications show that random Laguerre tessellations generates by systems
> of non-overlapping spheres are promising models for foam structures. So,ad
> first,i have to make a matlab routine to generete a hard spheres packing.the
> algorithm is the seguent:
> First,i have to create a set of N spheres with x,y and z center coordinates
> uniformly distribuited in a parallelepipedal container and with diameters d
> chosen accordingly to a prescribed distribution function(in my case,poisson
> distribution). Thus,ovelappings of the spheres in the initial ocnfiguration are
> typical. Then i have to reduce these overlaps.
> After this non-overlapping system of dense spheres is created,i have to find
> each y point that satisfy this relationship
>    ||x(1)-y||^2-r(1)^2 <= ||x(2)-y||^2-r(2)^2
> where
> x(1)= x,y,z center coordinates vector of a first sphere
> r(1)= radius of the first sphere
> x(2)=x,y,z center coordinates vector of a second sphere
> r(2)= radius of the second sphere
> y= x,y,z coordinates vector of y points satisfying the relationship.
> I want to obtain this using CGAL and i have read that you had the same problem
> some years ago.
> It would be a big pleasure for me if you could answer and help me in such
> way,like a code of a piece of it.
> I hope in your answer.
> With best regards,
>  Francesco Perrone
-- You are currently subscribed to cgal-discuss.
