cgal-discuss - Re: [cgal-discuss] Joining faces in polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Joining faces in polyhedron
  • Date: Wed, 06 May 2009 23:41:13 +0200
Thanks for the help, the iteration works now.
Sorry, I dont really know what an antenna is in the context of a polyhedron.
I will try to clarify what I want to do:
My input mesh is a triangle mesh, for example a cube.
This cube consists of 12 triangles, 2 for each side.
What I want to have is a polyhedron with 6 polygons (quads in this case).
For the simple example of the cube it works well, but when I want to do the
same with a triangulated quad consisting of many triangles, there are many
edges which can not be joined via polyhedron.join_facet(...).
I dont really know the reason for that, it would be nice if someone could
explain that.
Joel
-------- Original-Nachricht --------
> Datum: Wed, 06 May 2009 21:48:52 +0200
> Von: "Dr. J.K. Becker"
> An:
> Betreff: Re: [cgal-discuss] Joining faces in polyhedron
> I am not sure if I really understood this Mathieu, but would that not be
> an antenna which CGAL really does not like at all anyway (CGAL is happy
> to produce one, but any further operations on a polyhedron with an
> antenna will fail, at least it does for me)? And no, as far as I know,
> there are no build in checks for antennas...
> Anyway, polyhedra (or polygons) can have holes, no problem with that in
> CGAL.
> Joel, I am not sure I understood what you want to do correctly, but if
> you want to join all incident facets of a 3D triangulation that have
> the same normal, you will not join anything really (at least you will
> most likely never end up with a closed polyhedron)?! Except if you
> started of with a regular grid of points for the triangulation, but in
> that case you dont really need to triangulate anything? I am trying to
> figure out something very similar (and have not solved it) so maybe I am
> completely wrong....
> Jens
> On Wed, 2009-05-06 at 18:08 +0200, Mathieu Brédif wrote:
> > Hi,
> > If I am not mistaken, polyhedral facets may not have holes in CGAL.
> > This means that you can only remove edges if they are not adjacent to
> > the same face on both sides.
> > Mathieu
> > On Wed, May 6, 2009 at 5:52 PM, Andreas Fabri
> > wrote:
> > > Hi Joel,
> > > You must make a copy of the iterator, increment it and then work on
> the copy
> > > in the body of the loop.
> > > This is because the halfedges are in an in-place list, your join
> operation
> > > removes them and the iterator
> > > no longer points on something reasonable
> > > for ( Halfedge_iterator j = polyhedron.halfedges_begin(); j !=
> > > polyhedron.halfedges_end(); ){
> > > Halfedge_iterator i = j;
> > > ++j;
> > > // and now your code again
> > > I think you have even to increment j twice, as the twin halfedges are
> stored
> > > consecutively.
> > > Alternatively you should use an Edge_iterator.
> > > andreas
> > > wrote:
> > >> Hi!
> > >> I am trying to convert a triangle mesh to a polyhedron, i.e. I want
> to
> > >> join all faces which are adjacent and have the same normal
> > >> As an easy example I chose a flat patch consisting of triangles in
> .off
> > >> format. As a result I want to have a polyhedron consisting of a
> single
> > >> polygon.
> > >> I was able to load the file, but the follwoing did not work:
> > >> for ( Halfedge_iterator i = polyhedron.halfedges_begin(); i !=
> > >> polyhedron.halfedges_end(); ++i) {
> > >> if( i->is_border_edge() )
> > >> continue;
> > >> Polyhedron::Facet_handle f1 = i->facet();
> > >> Polyhedron::Facet_handle f2 = i->opposite()->facet();
> > >> Halfedge_handle he1 = f1->halfedge();
> > >> Point_3 p0 = he1->vertex()->point();
> > >> Point_3 p1 = he1->next()->vertex()->point();
> > >> Point_3 p2 = he1->next()->next()->vertex()->point();
> > >> Kernel::Vector_3 n_i = CGAL::cross_product(p0-p2, p1-p2);
> > >> n_i = n_i / sqrt(n_i.squared_length());
> > >> Halfedge_handle he2 = f2->halfedge();
> > >> p0 = he2->vertex()->point();
> > >> p1 = he2->next()->vertex()->point();
> > >> p2 = he2->next()->next()->vertex()->point();
> > >> Kernel::Vector_3 n_j = CGAL::cross_product(p0-p2, p1-p2);
> > >> n_j = n_j / sqrt(n_j.squared_length());
> > >> if(n_i == n_j)
> > >> if( circulator_size(i->opposite()->vertex_begin()) >= 3 &&
> > >> circulator_size(i->vertex_begin()) >= 3 )
> > >> polyhedron.join_facet(i);
> > >> There seem to be 2 problems: - after joining to faces the iterator
> becomes
> > >> invalid
> > >> - some faces cannot be joined, but why and how can I change that?
> > >> Can anyone help me please?
> > >> Have a nice day,
> > >> Joel
> > > You are currently subscribed to cgal-discuss.
> > > To unsubscribe or access the archives, go to
> > > https://lists-sop.inria.fr/wws/info/cgal-discuss
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen:
http://www.gmx.net/de/go/multimessenger01
