cgal-discuss - Re: [cgal-discuss] Joining faces in polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Joining faces in polyhedron
  • Date: Thu, 07 May 2009 11:44:59 +0200
Okay, thanks for your help.
Here is my minimalistic example:
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
typedef Kernel::Point_3 Point_3;
typedef Polyhedron::Facet_iterator Facet_iterator;
typedef Polyhedron::Halfedge_iterator Halfedge_iterator;
Polyhedron polyhedron;
ifstream fin ("model.off");
fin >> polyhedron;
for ( Halfedge_iterator j = polyhedron.halfedges_begin(); j !=
polyhedron.halfedges_end(); )
Halfedge_iterator i = j;
j++;
if( i->is_border_edge() )
continue;
Polyhedron::Facet_handle f1 = i->facet();
Polyhedron::Facet_handle f2 = i->opposite()->facet();
Halfedge_handle he1 = f1->halfedge();
Point_3 p0 = he1->vertex()->point();
Point_3 p1 = he1->next()->vertex()->point();
Point_3 p2 = he1->next()->next()->vertex()->point();
Kernel::Vector_3 n_i = CGAL::cross_product(p0-p2, p1-p2);
n_i = n_i /sqrt(n_i.squared_length());
Halfedge_handle he2 = f2->halfedge();
p0 = he2->vertex()->point();
p1 = he2->next()->vertex()->point();
p2 = he2->next()->next()->vertex()->point();
Kernel::Vector_3 n_j = CGAL::cross_product(p0-p2, p1-p2);
n_j = n_j /sqrt(n_j.squared_length());
if(n_i == n_j)
if( circulator_size(i->opposite()->vertex_begin()) >= 3 &&
circulator_size(i->vertex_begin()) >= 3 )
++j;
polyhedron.join_facet(i);
else
std::cout << "faces could not be joined\n";
The model is consiting of 4 triangles in a plane, so I would expect a quad as
output, instead I get 2 remaining triangles.
Here is the model in .off format:
OFF
5 4 0
-100 -100 0
100 -100 0
100 100 0
-100 100 0
0 0 0
3 3 0 4
3 4 2 3
3 1 4 0
3 2 4 1
Greetings,
Joel
Andreas Fabri schrieb:
> Joel,
> it would be helpful, if you saved the polyhedron just before the join
> operation fails.
> Ideally, you provide a minimalistic example, and you tell us on which edge,
> that is
> which two points, it fails. Then we can try to have a look.
> andreas
> wrote:
>> Thanks for the help, the iteration works now.
>> Sorry, I dont really know what an antenna is in the context of a
>> polyhedron.
>> I will try to clarify what I want to do:
>> My input mesh is a triangle mesh, for example a cube.
>> This cube consists of 12 triangles, 2 for each side.
>> What I want to have is a polyhedron with 6 polygons (quads in this case).
>> For the simple example of the cube it works well, but when I want to do
>> the same with a triangulated quad consisting of many triangles, there are
>> many edges which can not be joined via polyhedron.join_facet(...).
>> I dont really know the reason for that, it would be nice if someone could
>> explain that.
>> Joel
>> -------- Original-Nachricht --------
>>> Datum: Wed, 06 May 2009 21:48:52 +0200
>>> Von: "Dr. J.K. Becker"
>>> An:
>>> Betreff: Re: [cgal-discuss] Joining faces in polyhedron
>>> I am not sure if I really understood this Mathieu, but would that not be
>>> an antenna which CGAL really does not like at all anyway (CGAL is happy
>>> to produce one, but any further operations on a polyhedron with an
>>> antenna will fail, at least it does for me)? And no, as far as I know,
>>> there are no build in checks for antennas...
>>> Anyway, polyhedra (or polygons) can have holes, no problem with that in
>>> CGAL.
>>> Joel, I am not sure I understood what you want to do correctly, but if
>>> you want to join all incident facets of a 3D triangulation that have
>>> the same normal, you will not join anything really (at least you will
>>> most likely never end up with a closed polyhedron)?! Except if you
>>> started of with a regular grid of points for the triangulation, but in
>>> that case you dont really need to triangulate anything? I am trying to
>>> figure out something very similar (and have not solved it) so maybe I am
>>> completely wrong....
>>> Jens
>>> On Wed, 2009-05-06 at 18:08 +0200, Mathieu Brédif wrote:
>>>> Hi,
>>>> If I am not mistaken, polyhedral facets may not have holes in CGAL.
>>>> This means that you can only remove edges if they are not adjacent to
>>>> the same face on both sides.
>>>> Mathieu
>>>> On Wed, May 6, 2009 at 5:52 PM, Andreas Fabri
>>>> wrote:
>>>>> Hi Joel,
>>>>> You must make a copy of the iterator, increment it and then work on
>>> the copy
>>>>> in the body of the loop.
>>>>> This is because the halfedges are in an in-place list, your join
>>> operation
>>>>> removes them and the iterator
>>>>> no longer points on something reasonable
>>>>> polyhedron.halfedges_end(); ){
>>>>> ++j;
>>>>> // and now your code again
>>>>> I think you have even to increment j twice, as the twin halfedges are
>>> stored
>>>>> consecutively.
>>>>> Alternatively you should use an Edge_iterator.
>>>>> andreas
>>>>> wrote:
>>>>>> Hi!
>>>>>> I am trying to convert a triangle mesh to a polyhedron, i.e. I want
>>> to
>>>>>> join all faces which are adjacent and have the same normal
>>>>>> As an easy example I chose a flat patch consisting of triangles in
>>> .off
>>>>>> format. As a result I want to have a polyhedron consisting of a
>>> single
>>>>>> polygon.
>>>>>> I was able to load the file, but the follwoing did not work:
>>>>>> for ( Halfedge_iterator i = polyhedron.halfedges_begin(); i !=
>>>>>> polyhedron.halfedges_end(); ++i) {
>>>>>> continue;
>>>>>> n_i = n_i / sqrt(n_i.squared_length());
>>>>>> n_j = n_j / sqrt(n_j.squared_length());
>>>>>> if(n_i == n_j)
>>>>>> There seem to be 2 problems: - after joining to faces the iterator
>>> becomes
>>>>>> invalid
>>>>>> - some faces cannot be joined, but why and how can I change that?
>>>>>> Can anyone help me please?
>>>>>> Have a nice day,
>>>>>> Joel
>>>>> You are currently subscribed to cgal-discuss.
>>>>> To unsubscribe or access the archives, go to
>>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Eingehende eMail ist virenfrei.
> Von AVG überprüft - www.avg.de
> Version: 8.5.325 / Virendatenbank: 270.12.19/2099 - Ausgabedatum: 05/05/09
> 13:07:00
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen:
http://www.gmx.net/de/go/multimessenger01
