cgal-discuss - Re: [cgal-discuss] 3D surface mesh generation
  • To:
  • Subject: Re: [cgal-discuss] 3D surface mesh generation
  • Date: Tue, 19 May 2009 18:31:41 +0200
On Tuesday 19 May 2009 18:20:27 Daniel Russel wrote:
> >> Surface_3 surface(ellipsoid_function, // pointer to function
> >> Sphere_3(CGAL::ORIGIN, 3.5)); // bounding sphere
> > Your bounding sphere is defined with a *squared* radius of 3.5, and
> > clearly
> > that sphere does not bound the surface. In my opinion, you need at
> > least 10 as
> > *squared* radius of the sphere.
> > http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Kernel_23_ref/Class_S
> >phere_3.html
> As someone who gets bitten by this periodically when using the surface
> mesher, I would really appreciate if there is were a test in the code
> which could give a better error message if you mess this up.
I do not see any way to discover that a user gives an incorrect bounding
sphere. The bounding is part of the user input itself. What would be doable
is the detection that the bounding sphere is completely inside the interior
of
the surface (and in that case the mesher fails to discover any initial point).
But that is all. One can, for example, give the equation of a infinite
implicit surface, such as x^x+y^x-1 = 0, and the bounding sphere gives the
limit of the output surface mesh (in that case it is very important that the
tag CGAL::Manifold_with_boundaries_tag is used instead of CGAL::Manifold_tag).
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
