- To:
- Subject: Re: [cgal-discuss] 3D surface mesh generation
- Date: Wed, 20 May 2009 11:50:51 +0200
Laurent Rineau (GeometryFactory) wrote: I agree that the bounding sphere could be used to clip the surfaceOn Tuesday 19 May 2009 18:20:27 Daniel Russel wrote:Surface_3 surface(ellipsoid_function, // pointer to function Sphere_3(CGAL::ORIGIN, 3.5)); // bounding sphereYour bounding sphere is defined with a *squared* radius of 3.5, and clearly that sphere does not bound the surface. In my opinion, you need at least 10 as *squared* radius of the sphere. http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Kernel_23_ref/Class_S phere_3.htmlAs someone who gets bitten by this periodically when using the surface mesher, I would really appreciate if there is were a test in the code which could give a better error message if you mess this up.I do not see any way to discover that a user gives an incorrect bounding sphere. The bounding is part of the user input itself. What would be doable is the detection that the bounding sphere is completely inside the interior of the surface (and in that case the mesher fails to discover any initial point). But that is all. One can, for example, give the equation of a infinite implicit surface, such as x^x+y^x-1 = 0, and the bounding sphere gives the limit of the output surface mesh (in that case it is very important that the tag CGAL::Manifold_with_boundaries_tag is used instead of CGAL::Manifold_tag). to be meshed but this is not really the intention of this bounding sphere... On the other hand, there is no way to test if the given bounding sphere is really bounding ... except may be, in case of closed surface, a statistical test that amounts to take random point on this sphere and check that the segments from these point to the center point intersects the surface. -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] 3D surface mesh generation, weihy1984, 05/19/2009
- Re: [cgal-discuss] 3D surface mesh generation, Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] 3D surface mesh generation, Daniel Russel, 05/19/2009
- Re:Re: [cgal-discuss] 3D surface mesh generation, weihy1984, 05/20/2009
- Re: [cgal-discuss] 3D surface mesh generation, Mariette Yvinec, 05/20/2009
