cgal-discuss - Re:Re: [cgal-discuss] error: `TAUCS_FLAG' is not a member of
  • To: cgal-discuss <>
  • Subject: Re:Re: [cgal-discuss] error: `TAUCS_FLAG' is not a member of
  • Date: Thu, 21 May 2009 09:00:31 +0800 (CST)
Hi ,Laurent Saboret, i modified my CMakeList.txt and CMakeCache.txt as you suggested,and it works, thank you very much.
best regards.
在2009-05-20,"Laurent Saboret" <> 写道:
>Hi,
>The error below is a link error due to the taucs_ccs_free() function missing. You should
>link with TAUCS.
>Finding the proper libraries to link with TAUCS is tedious, thus I recommend you to cut
>and paste the code related to TAUCS in
>CGAL-3.4/examples/Surface_mesh_parameterization/CMakeLists.txt (assuming that you use CMake).
>Best regards,
>Laurent Saboret
>INRIA Sophia-Antipolis
>sanlington a écrit :
>> yes, i tried to instanciate Taucs_matrix<T> with CGAL::FT. After i
>> instanciated it with float or double, that error disappeared,but there
>> is another error occured:
>> CMakeFiles/Mesh.dir/Mesh.o(.text+0xfa1): In function
>> `Con_Delaunay3D::compute_fi nite_element_equation()':
>> : undefined reference to `taucs_ccs_free'
>> CMakeFiles/Mesh.dir/Mesh.o(.text+0xfd8): In function
>> i thought that might because Taucs is a C library, so including
>> <CGAL/Taucs_fix.h> might fix it, but it did not.
>> What should i do ?
>> thanks.
>>>Hi,
>>>According to the code (Taucs_matrix.h), I guess that you are trying to instanciate
>>>Taucs_matrix<T> with T different from float and double.Unfortunately, only float and
>>>double are supported.
>>>Best regards,
>>>Laurent Saboret
>>>sanlington wrote:
>>>> i am using cgal-3.4, platform is Linux, part of my included header files is:
>>>> #include<CGAL/Taucs_fix.h>
>>>> #include<CGAL/Taucs_solver_traits.h>
>>>> #include<CGAL/Taucs_matrix.h>
>>>> #include<CGAL/Taucs_vector.h>
>>>> when i compiled my cgal application, the following error is displayed:
>>>>  error: `TAUCS_FLAG' is not a member of `CGAL::Taucs_traits<FT>'
>>>> can anybody help me out ?
>>>> thanks.
>>>> 穿越地震带 纪念汶川地震一周年
>>>> <http://512.mail.163.com/mailstamp/stamp/dz/activity.do?from=footer>
>>>You are currently subscribed to cgal-discuss.
>>>To unsubscribe or access the archives, go to
>>>https://lists-sop.inria.fr/wws/info/cgal-discuss
>> 穿越地震带 纪念汶川地震一周年
>Laurent Saboret
>Project GEOMETRICA
>(33) 4 97 15 53 09
穿越地震带 纪念汶川地震一周年
