- To:
- Subject: Re: [cgal-discuss] error: `TAUCS_FLAG' is not a member of
- Date: Wed, 20 May 2009 11:50:16 +0200
Hi,
The error below is a link error due to the taucs_ccs_free() function missing. You should link with TAUCS.
Finding the proper libraries to link with TAUCS is tedious, thus I recommend you to cut and paste the code related to TAUCS in CGAL-3.4/examples/Surface_mesh_parameterization/CMakeLists.txt (assuming that you use CMake).
Best regards,
Laurent Saboret
INRIA Sophia-Antipolis
sanlington a ??crit :
yes, i tried to instanciate Taucs_matrix<T> with CGAL::FT. After i instanciated it with float or double, that error disappeared,but there is another error occured:
CMakeFiles/Mesh.dir/Mesh.o(.text+0xfa1): In function `Con_Delaunay3D::compute_fi nite_element_equation()':
: undefined reference to `taucs_ccs_free'
CMakeFiles/Mesh.dir/Mesh.o(.text+0xfd8): In function `Con_Delaunay3D::compute_fi nite_element_equation()':
i thought that might because Taucs is a C library, so including <CGAL/Taucs_fix.h> might fix it, but it did not.
What should i do ?
thanks.
??2009-05-20??"Laurent Saboret"
Hi,
According to the code (Taucs_matrix.h), I guess that you are trying to instanciate Taucs_matrix<T> with T different from float and double.Unfortunately, only float and double are supported.
Best regards,
Laurent Saboret
sanlington wrote:
i am using cgal-3.4, platform is Linux, part of my included header files is:
#include<CGAL/Taucs_fix.h>
#include<CGAL/Taucs_solver_traits.h>
#include<CGAL/Taucs_matrix.h>
#include<CGAL/Taucs_vector.h>
when i compiled my cgal application, the following error is displayed:
error: `TAUCS_FLAG' is not a member of `CGAL::Taucs_traits<FT>'
can anybody help me out ?
thanks.
?????????? ?????????????????? <http://512.mail.163.com/mailstamp/stamp/dz/activity.do?from=footer>
Laurent Saboret
Project GEOMETRICA
(33) 4 97 15 53 09
- [cgal-discuss] error: `TAUCS_FLAG' is not a member of `CGAL::Taucs_traits<FT>', sanlington, 05/19/2009
- Re: [cgal-discuss] error: `TAUCS_FLAG' is not a member of `CGAL::Taucs_traits<FT>', Laurent Saboret, 05/20/2009
- Re:Re: [cgal-discuss] error: `TAUCS_FLAG' is not a member of, sanlington, 05/20/2009
- Re: [cgal-discuss] error: `TAUCS_FLAG' is not a member of, Laurent Saboret, 05/20/2009
- Re:Re: [cgal-discuss] error: `TAUCS_FLAG' is not a member of, sanlington, 05/21/2009
