- To:
- Subject: Re: [cgal-discuss] install CGAL on unix sol86 platform
- Date: Fri, 22 May 2009 11:45:19 +0200
Hi,
> Can anyone share some experience on how to install CGAL 3.3 or 3.4 on UNIX
> sol86 platform? I tried to install it on this platform, but couldn't
> succeed. According to CGAL installation manual, it requires g++ 4.1
> compiler. I am not sure if I can use gcc 4.1.1 instead. Thank you in
> advance.
If you read "gcc" as "GNU Compiler Collection", then the answer is yes,
since it contains the C++ compiler. If you read "gcc" as GNU C Compiler,
then the answer is no, you really need the C++ compiler.
I strongly suggest using CGAL 3.4 and not 3.3.
Maybe we can help you if you let us know the error message (and more
details, see http://www.cgal.org/bug_report.html).
Joachim
- [cgal-discuss] install CGAL on unix sol86 platform, Shu Ye, 05/21/2009
- Re: [cgal-discuss] install CGAL on unix sol86 platform, Joachim Reichel, 05/22/2009
