- To:
- Subject: [cgal-discuss] Euclidean distance Point_3 to Triangle
- Date: Fri, 22 May 2009 16:33:40 +0200 (CEST)
Hello,
I have two questions:
1. Is there a way to calculate the euclidean (minimal) distance between a 3d
Point and an triangle (from three 3d points)?
2. Is there an efficient way to locate the triangle with the minimum distance
to a certain point directly if I have an Triangulation with many triangles?
Thanks for any help!
- [cgal-discuss] Euclidean distance Point_3 to Triangle, matthias.kunz, 05/22/2009
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, Pierre Alliez, 05/24/2009
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, Bernd Gaertner, 05/25/2009
- Re: Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, matthias.kunz, 05/25/2009
- RE: Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, Amir Vaxman, 05/25/2009
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, Pierre Alliez, 05/25/2009
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, Camille Wormser, 05/25/2009
