- To:
- Subject: Re: [cgal-discuss] a question concerning the union of polygons
- Date: Sun, 24 May 2009 23:49:55 +0900
Hi efif, Jens and Ben,
Thanks for your answers!
As I didn't have much time and don't need the best of all possible
solutions, I finally followed Ben's last mentioned pragmatic approach
and just stored the vertices in a hash:
> Finally a totally different approach would be: simply store a tree of
> vertices...since the coordinates will be unmodified from the original
to
> the destination vertices, I think you could use a lexicographical
sort
> to build a sorted array or tree of vertices for fast lookup to source
> polygon by coordinate.
It seems to work fine :)
Thanks again, Dietrich
Sorry for answering late. I was busy and didn't find the time to test
this approach before...
On Tue, 2009-05-12 at 10:58 +0200, Jens K. Becker wrote:
Hi all,
> I am not sure if that also applies to the 2D case of polygons, but in
3D
> you can add information to the vertices (or anything else). Thus you
> could store ID's in your original polygon and look for them in the
> resulting polygon.
> See
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Polyhedron/Chapter_main.html
> for the 3D example how to do that. Again, I am not sure if that also
> works in 2D.
> Jens
On Wed, 2009-05-13 at 10:09 +0300,
wrote:
Indeed. It also works in the 2D case. You can extend the DCEL records
> of the underlying arrangement and use it when you define your
Polygon
> set (CGAL::Polygon_set_2<Kernel,Container,Extended_dcel>).
> Quoting "Jens K. Becker"
On Thu, 2009-05-07 at 08:36 -0400, Ben Supnik wrote:
> Hi Dietrich,
> The general polygon set code is built on top of (and templated by)
> arrangement_2. So in my code, I do some tricks using this.
> While you can add data to the arrangement_2 elements (vertices,
> halfedges, faces) I think this isn't quite what you want for two reasons:
> - CGAL does not have a general "vertex with history" concept to let you
> remember what vertex came from where. E.g. if a vertex is from more
> than one polygon, it may not be obvious which one it came from and...
> - I believe that you don't get to provide a "merge rule" for
> arrangement_2 data when doing polygon ops. In other words, the meta
> data won't be copied appropriately from your input arrangements (if you
> convert your input polygons into arrangements) to your final ones.
> I think the "right" way to do this is: use an arrangement with
> consolidated curve data. Consolidated curve data means that you can have
> an STL set of data per underlying curve. The result will be that you
> can have a set of IDs for each edge in the final map that match the
> input map. Thus you could relocate A and C and since A and C have
> direction, you an find a1, a4, c1, and c8.
> If you use this strategy, you'll need to check for the cases where an
> underlying curve is either split or reversed in direction...if it is
> split, only one end of it points to a vertex of interest.
> An edge can be reversed in direction when the same edge (of opposite
> direction) is present in two different polygons - the arrangement_2 only
> stores one "curve" (with direction) per complete edge.
> vertices...since the coordinates will be unmodified from the original to
> the destination vertices, I think you could use a lexicographical sort
> cheers
> BEn
> Dietrich Bollmann wrote:
> > Hi,
> > I am experimenting with the union of polygons and wonder, if there is
> > some way to determine which vertices from the resulting polygon
> > correspond to which vertices of the original polygons.
> > Here comes an example:
> > Union operation:
> > A = [(0, 3), (0, 1), (2, 1), (2, 3)]
> > B = [(1, 2), (1, 0), (3, 0), (3, 2)]
> > a1 A a4 c1 C c8
> > 3 o-----o o-----o
> > | b1 | b4 | | c6
> > 2 | o--+--o | x--o
> > | | | | =union=> | c3 c7 | B
> > 1 o--+--o | B o--x |
> > a2 | a3 | c2 | |
> > 0 o-----o o-----o
> > b2 b3 c4 c5
> > 0 1 2 3 0 1 2 3
> > And here what I am interested in:
> > Vertex Mapping: C X A U B U {inserted}
> > (c1, a1), (c2, a2),
> > (c3, inserted),
> > (c4, b2), (c5, b3), (c6, b4),
> > (c7, inserted),
> > (c8, a4)
> >>From Joachim Reichel I got the idea to mark the vertices of the original
> > polygons and to later look for the markers in the resulting polygon.
> > But I couldn't find any information about markers in the manual...
> > Any idea?
> > Thanks, Dietrich
> > Here the same example (wrapped into Python):
> >>>> from CGAL import do_intersect, join
> >>>> from CGAL.Polygon import Polygon
> >>>> from CGAL.Kernel import Point_2
> >>>> # Construct the two input polygons.
> >>>> p = Polygon([Point_2(v[0], v[1]) for v in A])
> >>>> q = Polygon([Point_2(v[0], v[1]) for v in B])
> >>>> print "p = ",; p.pretty_print()
> > p = { 4 vertices: [(0, 3), (0, 1), (2, 1), (2, 3)] }
> >>>> print "q = ",; q.pretty_print()
> > q = { 4 vertices: [(1, 2), (1, 0), (3, 0), (3, 2)] }
> >>>> # Compute the union of P and Q.
> >>>> union = join(p, q)
> >>>> print "union = ",; union.pretty_print()
> > union = { Outer boundary = { 8 vertices: [(1, 0), (3, 0), (3, 2), (2,
> > 2), (2, 3), (0, 3), (0, 1), (1, 1)] }
> > 0 holes:
> Scenery Home Page: http://scenery.x-plane.com/
> Scenery blog: http://xplanescenery.blogspot.com/
> Plugin SDK: http://www.xsquawkbox.net/xpsdk/
> X-Plane Wiki: http://wiki.x-plane.com/
> Scenery mailing list:
> Developer mailing list:
- [cgal-discuss] a question concerning the union of polygons, Dietrich Bollmann, 05/07/2009
- Re: [cgal-discuss] a question concerning the union of polygons, Ben Supnik, 05/07/2009
- Re: [cgal-discuss] a question concerning the union of polygons, Jens K. Becker, 05/12/2009
- Re: [cgal-discuss] a question concerning the union of polygons, efif, 05/13/2009
- [cgal-discuss] Custom Vertex type in Polyhedron_3, Matthias Teich, 05/13/2009
- Re: [cgal-discuss] a question concerning the union of polygons, Dietrich Bollmann, 05/24/2009
