cgal-discuss - Re: [cgal-discuss] Euclidean distance Point_3 to Triangle
  • To:
  • Subject: Re: [cgal-discuss] Euclidean distance Point_3 to Triangle
  • Date: Sun, 24 May 2009 14:31:52 +0200
  • Organization: INRIA
hi Matthias,
we are working on a CGAL component to compute such distances. hopefully it will make it in the next release.
I will send you the current code so that you can test it.
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
a écrit :
Hello,
I have two questions:
1. Is there a way to calculate the euclidean (minimal) distance between a 3d
Point and an triangle (from three 3d points)?
2. Is there an efficient way to locate the triangle with the minimum distance
to a certain point directly if I have an Triangulation with many triangles?
Thanks for any help!
