- To:
- Subject: [cgal-discuss] CGAL 3.4 install - vc8 | winXP
- Date: Wed, 3 Jun 2009 06:19:01 +0200 (CEST)
I am hoping someone can help diagnose an installation issue I have been having
with CGAL 3.4.
Using cmake, I have successfully compiled CGAL using VC8. (Several times,
with
several different configurations.) Linking to this build, I have been able to
compile various example files. But these example file .exe s fail when run,
with the following error message:
"This application has failed to start because gmp-vc80-mt-gd.dll was not
found.
Re-installing the application may fix this problem."
I am using the precompiled gmp libraries directly from the windows installer.
Looking through the help docs, it appears that windows does not support
dynamic
libraries. But I have not been able to build a static library, even setting
CMAKE_SHARED_LIBS = FALSE . I am hoping someone might be able to point me in
the right direction re: how to address this issue. E.g., is it a static vs.
dynamic library issue. Or is the gmp dll somehow corrupt? Thanks!
- Luke
- [cgal-discuss] CGAL 3.4 install - vc8 | winXP, luke, 06/03/2009
- Re: [cgal-discuss] CGAL 3.4 install - vc8 | winXP, Leon Nan, 06/03/2009
- Re:[cgal-discuss] CGAL 3.4 install - vc8 | winXP, Yao Lingqing, 06/04/2009
