cgal-discuss - Re: [cgal-discuss] CGAL 3.4 install - vc8 | winXP
  • To: "cgal-discuss" <>
  • Subject: Re: [cgal-discuss] CGAL 3.4 install - vc8 | winXP
  • Date: Wed, 3 Jun 2009 14:13:58 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=date:from:to:references:subject:message-id:x-mailer:mime-version :content-type; b=FDY8rcb2gG4kYldksV1u5ft3EyHsVLEkh+eRWaRzln+e9IZE8AdugCJOIEsJUBihs3 LBSrsZxpnahcxd1d9JXiqLZfzaRDRl6XZaYrb8w0+JFGpAKrmDDPuQ1vmCYwt6yI/KMS JNbpb2kaoZpJ0fr+8bzgASs3Vd5T2G83X5Nq0=
It's quite strange encountering this issue.
I suggest you copy the .dll to the directory where your .exe exists to check that the .dll is corrupt or not. And then we can make further discussion.
Leon Nan
2009-06-03
发件人:
发送时间: 2009-06-03 12:20:58
收件人: cgal-discuss
抄送:
主题: [cgal-discuss] CGAL 3.4 install - vc8 | winXP
I am hoping someone can help diagnose an installation issue I have been having
with CGAL 3.4.
Using cmake, I have successfully compiled CGAL using VC8.  (Several times, with
several different configurations.)  Linking to this build, I have been able to
compile various example files. But these example file .exe s fail when run,
with the following error message:
"This application has failed to start because gmp-vc80-mt-gd.dll was not found.
 Re-installing the application may fix this problem."
I am using the precompiled gmp libraries directly from the windows installer.
Looking through the help docs, it appears that windows does not support dynamic
libraries.  But I have not been able to build a static library, even setting
CMAKE_SHARED_LIBS = FALSE .  I am hoping someone might be able to point me in
the right direction re: how to address this issue.  E.g., is it a static vs.
dynamic library issue. Or is the gmp dll somehow corrupt?  Thanks!
- Luke
You are currently subscribed to cgal-discuss.
To unsubscribe or access the archives, go to
