- To:
- Subject: [cgal-discuss] point location with arr_circle_segment_traits
- Date: Wed, 10 Jun 2009 19:40:50 +0200 (CEST)
When I try to use the standard point location query with my traits it don't
work cause I've the following error:
/usr/local/include/CGAL/Arr_point_location/Arr_lm_nearest_neighbor.h ‘class
CGAL::Arr_circle_segment_traits_2<CGAL::Cartesian<CGAL::Quotient<CGAL::MP_Float>
>, true>’ has no member named ‘approximate_2_object’
So how can I perform a point location function when I'm working with the
arr_circle_segment_traits?
- [cgal-discuss] point location with arr_circle_segment_traits, Denny, 06/10/2009
- Re: [cgal-discuss] point location with arr_circle_segment_traits, Ophir Setter, 06/11/2009
- Re: Re: [cgal-discuss] point location with arr_circle_segment_traits, Denny, 06/11/2009
