- To:
- Subject: Re: [cgal-discuss] Looping through vertices of a face
- Date: Fri, 12 Jun 2009 14:14:03 +0200
Hi Matthew,
The triangulation is parameterized with a triangulation datastructure
which is parameterized with a vertex and face class.
______________________________________________
Parameters
The class Triangulation_2<Traits,Tds> has two template parameters. The first one Traits is the geometric traits, it is to be instantiated by a model of the concept TriangulationTraits_2.
The second parameter is the triangulation data structure, it has to be instantiated by a model of the concept TriangulationDataStructure_2. By default, the triangulation data structure is instantiated by CGAL::Triangulation_data_structure_2 < CGAL::Triangulation_vertex_base_2<Gt>, CGAL::Triangulation_face_base_2<Gt> > >.
Source:
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Cross_link_anchor_1166
Whe you click on CGAL::Triangulation_face_base_2<Gt> you find
Is Model for the Concepts
TriangulationFaceBase_2
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_face_base_2.html
"Model of a concept" means implementations of a specification,
so when you click on TriangulationFaceBase_2 and there on
TriangulationDSFaceBase_2
you are one click away from what you search
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/TDS_2_ref/Concept_TriangulationDSFaceBase_2.html#Cross_link_anchor_1178
The whole thing is rather decomposed, but it makes little sense to repeat the
documentation
of the concept for each model.
andreas
Matthew Denno wrote:
Hi,
I am hoping that someone can point me in the right direction to a
solution for my problem. I am new to both CGAL and C++ so I apologize
if my questions should be obvious.
I started out with one of the example problems. After I have added
the points to the Triangulation, I use a Face_iterator to iterate
through the faces (I think through this part is ok). The problem is I
can't figure out how to access the verticies of each face as I iterate
over them.
If someone could point me in the right direction I would really
appreciate it. Maybe just a hint of what I should look for in the
manual.
The code I have been testing with is below.
Thanks so much.
Matt
#include <fstream>
#include <CGAL/Triangulation_2.h>
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_2<K> Triangulation;
typedef Triangulation::Vertex_circulator Vertex_circulator;
typedef Triangulation::Point Point;
typedef Triangulation::Face_iterator Face_iterator;
typedef Triangulation::Vertex_handle Vertex_handle;
typedef Triangulation::Vertex_iterator Vertex_iterator;
int main() {
std::ifstream in("data/triangulation_prog1.cin");
std::istream_iterator<Point> begin(in);
std::istream_iterator<Point> end;
Triangulation t;
t.insert(begin, end);
for (Face_iterator fit = t.faces_begin();
fit != t.faces_end();
++fit){
//This is where the problem is.
//print out the x and y coordinates of all three verticies of each
face
return 0;
- [cgal-discuss] Looping through vertices of a face, Matthew Denno, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Panagiotis Foteinos, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Andreas Fabri, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Matthew Denno, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Matthew Denno, 06/15/2009
