- To:
- Subject: Re: [cgal-discuss] Looping through vertices of a face
- Date: Sun, 14 Jun 2009 21:51:34 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=Qi4iGr//VDhHZllZe3TU49q+NYRykkNgjZMP5n3xlcSjqvfuoxnrEN00zQObPZ25QI p8vGn9VFPPyKus205A9192FWKr7sjBl3MYkQ/gQCYn1tAi8azr5axS39JKt9EOixCpqd FmIRo8b/2VYNWZjy20VwTEdSFJbgR4QMfVLJU=
Hi Andreas,
Thank you for the explanation.
Matt
On Fri, Jun 12, 2009 at 11:49 AM, Andreas
Fabri<>
wrote:
> Hi Matthew,
> It's -> and not . because f is a Face_handle and not a Face, and
> a handle is something like a pointer.
> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Circulator_ref/Concept_Handle.html
> Note that all iterators are also model of the concept Handle
> andreas
> Matthew Denno wrote:
>> Thanks so much to both of you for your help. I really appreciate you
>> taking time to answer my novice questions as I learn.
>> I think I am starting to learn my way around the documentation so that
>> I can hopefully figure it out on my own in the future.
>> One point of confusion for me still, which is probably more of a C++
>> question than a specific CGAL question is why, for example, in the
>> documentation it is shown as f.vertex() , but in code that was
>> provided (and works) it is f -> vertex(). I suspect that in the
>> documentation it is shown as f.vertex() to indicate that vertex() is a
>> member of f but why is it accessed using f->vertex()?
>> On Fri, Jun 12, 2009 at 8:14 AM, Andreas
>> Fabri<>
>> wrote:
>>> Hi Matthew,
>>> The triangulation is parameterized with a triangulation datastructure
>>> which is parameterized with a vertex and face class.
>>> ______________________________________________
>>> Parameters
>>> The class Triangulation_2<Traits,Tds> has two template parameters. The
>>> first
>>> one Traits is the geometric traits, it is to be instantiated by a model
>>> of
>>> the concept TriangulationTraits_2.
>>> The second parameter is the triangulation data structure, it has to be
>>> instantiated by a model of the concept TriangulationDataStructure_2. By
>>> default, the triangulation data structure is instantiated by
>>> CGAL::Triangulation_data_structure_2 <
>>> CGAL::Triangulation_vertex_base_2<Gt>,
>>> CGAL::Triangulation_face_base_2<Gt> >
>>> Source:
>>> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Cross_link_anchor_1166
>>> Whe you click on CGAL::Triangulation_face_base_2<Gt> you find
>>> Is Model for the Concepts
>>> TriangulationFaceBase_2
>>> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_face_base_2.html
>>> "Model of a concept" means implementations of a specification,
>>> so when you click on TriangulationFaceBase_2 and there on
>>> TriangulationDSFaceBase_2
>>> you are one click away from what you search
>>> http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/TDS_2_ref/Concept_TriangulationDSFaceBase_2.html#Cross_link_anchor_1178
>>> The whole thing is rather decomposed, but it makes little sense to repeat
>>> the documentation
>>> of the concept for each model.
>>> andreas
>>>> Hi,
>>>> I am hoping that someone can point me in the right direction to a
>>>> solution for my problem. I am new to both CGAL and C++ so I apologize
>>>> if my questions should be obvious.
>>>> I started out with one of the example problems. After I have added
>>>> the points to the Triangulation, I use a Face_iterator to iterate
>>>> through the faces (I think through this part is ok). The problem is I
>>>> can't figure out how to access the verticies of each face as I iterate
>>>> over them.
>>>> If someone could point me in the right direction I would really
>>>> appreciate it. Maybe just a hint of what I should look for in the
>>>> manual.
>>>> The code I have been testing with is below.
>>>> Thanks so much.
>>>> Matt
>>>> #include <fstream>
>>>> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
>>>> #include <CGAL/Triangulation_2.h>
>>>> struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
>>>> typedef CGAL::Triangulation_2<K> Triangulation;
>>>> typedef Triangulation::Vertex_circulator Vertex_circulator;
>>>> typedef Triangulation::Point Point;
>>>> typedef Triangulation::Face_iterator Face_iterator;
>>>> typedef Triangulation::Vertex_handle Vertex_handle;
>>>> typedef Triangulation::Vertex_iterator Vertex_iterator;
>>>> int main() {
>>>> std::ifstream in("data/triangulation_prog1.cin");
>>>> std::istream_iterator<Point> begin(in);
>>>> std::istream_iterator<Point> end;
>>>> Triangulation t;
>>>> t.insert(begin, end);
>>>> for (Face_iterator fit = t.faces_begin();
>>>> fit != t.faces_end();
>>>> ++fit){
>>>> //This is where the problem is.
>>>> //print out the x and y coordinates of all three verticies of each
>>>> face
>>>> return 0;
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Looping through vertices of a face, Matthew Denno, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Panagiotis Foteinos, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Andreas Fabri, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Matthew Denno, 06/12/2009
- Re: [cgal-discuss] Looping through vertices of a face, Matthew Denno, 06/15/2009
