- To:
- Subject: Re: [cgal-discuss] Euclidean distance Point_3 to Triangle
- Date: Tue, 14 Jul 2009 16:38:09 +0200 (CEST)
Hi,
I tried to use the AABB_tree (added to CGAL 3.4) as described in the manual.
However if I try to use the clostest_point I get an error message:
CGAL/Kernel/function_objects.h no matching function for call to
'do_intersect(const CGAL::Sphere_3<CGAL::Simple_cartesian<double> >&, const
CGAL::Bbox_3&, CGAL::Simple_cartesian<double>)'
I can't work out why, because the example (1.3.1 from manual) works until the
closest point calculation. Any ideas?
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, matthias.kunz, 07/14/2009
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, Pierre Alliez, 07/14/2009
