- To:
- Subject: Re: [cgal-discuss] Euclidean distance Point_3 to Triangle
- Date: Tue, 14 Jul 2009 18:06:47 +0200
- Organization: INRIA
dear Matthias,
the AABB tree in CGAL 3.4 was only used for intersection queries by the polyhedron demo - it was internal somehow.
for the next release we have a much more complete version - documented, etc. I am sending it to you right now.
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
a écrit :
Hi,
I tried to use the AABB_tree (added to CGAL 3.4) as described in the manual. However if I try to use the clostest_point I get an error message:
CGAL/Kernel/function_objects.h no matching function for call to
'do_intersect(const CGAL::Sphere_3<CGAL::Simple_cartesian<double> >&, const
CGAL::Bbox_3&, CGAL::Simple_cartesian<double>)'
I can't work out why, because the example (1.3.1 from manual) works until the
closest point calculation. Any ideas?
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, matthias.kunz, 07/14/2009
- Re: [cgal-discuss] Euclidean distance Point_3 to Triangle, Pierre Alliez, 07/14/2009
