cgal-discuss - Re: [cgal-discuss] Triangulation problem
  • To:
  • Subject: Re: [cgal-discuss] Triangulation problem
  • Date: Thu, 16 Jul 2009 13:41:26 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=AO5GOMbj/9Mnb4tLZxN2yr/m0KGcBw7R0/yheMvBo79Bend+lXri8RkmKSsvoxSF7P ALowvYxZXe7cBxiymfNKE7UqeZ59GGgGtIkNZA32IRX2pM0L5eqxDMhJAhhgvHKf+A7j MqnN5+2rr2kerIYGOYQUuBunKxn8EeyllhfoI=
Are you kidding?
Why don't you do this . . . .
          Point vertex = triangle.vertex(2);
          triangles.push_back(Vec3(vertex.x(), vertex.y(), vertex.z()));
       vertex = triangle.vertex(1);
       vertex = triangle.vertex(0);
Instead of this. . . . .
          Point vertex = triangle.vertex(0);
Damian
On Thu, Jul 16, 2009 at 1:19 PM, <> wrote:
Hello, Im trying to use CGAL to triangulate polygon and I run into problem with
triangle orientation. CGAL always generate counter clock wise triangles for
some polygons. Here is my code:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
   typedef CGAL::Triangulation_3<K> Triangulation;
   typedef Triangulation::Cell_handle Cell_handle;
   typedef Triangulation::Vertex_handle Vertex_handle;
   typedef Triangulation::Locate_type Locate_type;
   typedef Triangulation::Point Point;
   typedef Triangulation::Facet_iterator Facet_iterator;
   typedef Triangulation::Facet Facet;
   // construction from a list of points :
   std::list<Point> L;
       L.push_back(Point(0, 0, 0));
       Lpush_back(Point(25, 0, 0));
       Lpush_back(Point(25, 0, 25));
       Lpush_back(Point(0,0, 25));
   Triangulation T(L.begin(), L.end());
   for (Triangulation::Finite_facets_iterator fit = T.finite_facets_begin();
fit != T.finite_facets_end(); ++fit)
       K::Triangle_3 triangle = T.triangle(*fit);
can I somehow set Triangluation to give me clockwise triangles? thx for help
