- To:
- Subject: [cgal-discuss] Triangulation problem
- Date: Thu, 16 Jul 2009 19:19:30 +0200 (CEST)
Hello, Im trying to use CGAL to triangulate polygon and I run into problem
with
triangle orientation. CGAL always generate counter clock wise triangles for
some polygons. Here is my code:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_3<K> Triangulation;
typedef Triangulation::Cell_handle Cell_handle;
typedef Triangulation::Vertex_handle Vertex_handle;
typedef Triangulation::Locate_type Locate_type;
typedef Triangulation::Point Point;
typedef Triangulation::Facet_iterator Facet_iterator;
typedef Triangulation::Facet Facet;
// construction from a list of points :
std::list<Point> L;
L.push_back(Point(0, 0, 0));
Lpush_back(Point(25, 0, 0));
Lpush_back(Point(25, 0, 25));
Lpush_back(Point(0,0, 25));
Triangulation T(L.begin(), L.end());
for (Triangulation::Finite_facets_iterator fit = T.finite_facets_begin();
fit != T.finite_facets_end(); ++fit)
K::Triangle_3 triangle = T.triangle(*fit);
Point vertex = triangle.vertex(0);
triangles.push_back(Vec3(vertex.x(), vertex.y(), vertex.z()));
vertex = triangle.vertex(1);
vertex = triangle.vertex(2);
can I somehow set Triangluation to give me clockwise triangles? thx for help
- [cgal-discuss] Triangulation problem, icek, 07/16/2009
- Re: [cgal-discuss] Triangulation problem, Andreas Fabri, 07/16/2009
- Re: [cgal-discuss] Triangulation problem, Damian Sheehy, 07/16/2009
- Re: Re: [cgal-discuss] Triangulation problem, icek, 07/16/2009
- Re: [cgal-discuss] Triangulation problem, Ariel Baez, 07/16/2009
- Re: [cgal-discuss] Triangulation problem, Damian Sheehy, 07/17/2009
