- To:
- Subject: Re: [cgal-discuss] How to judge whether a point is an inner point
- Date: Sun, 19 Jul 2009 09:55:23 +0200
- Organization: INRIA
I have sent you the current AABB tree component which contains a
documentation with examples. best regards, pierre Yajun Wang a écrit : Hi Pierre, Yes, the model I used is both boundary-free and intersection-free . It will be great if you send me a component. How do I use this component? Do you have a manual about this component ? Thank you! Best Regards --Yajun-----Original Message----- From: Pierre Alliez Date: Wed, 15 Jul 2009 16:14:14 +0200 To: Subject: Re: [cgal-discuss] How to judge whether a point is an inner poi hi Yajun, do you mean that you have a triangle surface mesh represented eg as a CGAL polyhedron? if it is both boundary-free and intersection-free then yes - we are working (hopefully for the next release) on an AABB tree component which solves your problem. would you be interested in testing the component now? I could send it to you by email. Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 Yajun Wang a écrit :Hi ALL, I wonder if there are some functions in CGAL which could be used to judge whether a given point is an inner point of a triangle model ? And also are there some functions could be used to get the distance from a given point to the boundary of a triangle model ? Thank you ! Best regards, Yajun Wang-- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discussBest regards, Yajun Wang |
- Re: Re: [cgal-discuss] How to judge whether a point is an inner point, Yajun Wang, 07/19/2009
- Re: [cgal-discuss] How to judge whether a point is an inner point, Pierre Alliez, 07/19/2009
