- To:
- Subject: Re: [cgal-discuss] 2D Segment Voronoi Diagrams
- Date: Mon, 20 Jul 2009 02:28:41 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=Pu//WoPhKBcQm9QAytT53F5FM5F6MUVpt6FgM960M4ljNKMahjR2rWCVYqpH9za97c DrufHhF+t2gZ/Fj2cU9kKVzZvo+XvoBGKoIAVGYFNEJEABxqK4YW3OtEo5dOLXRqTPzC jylf5ETboq1mqBFeEa4IHjr4BaPcESAj8dUCA=
Thanks a lot... So I was checking out the delaunay segment diagram and I hope you could help me again...
I am having hard time to traverse it. I see that there are lot of circulators and iterators but i cannot understand how to use it...
for example i want to circulate it face by face:
SDG2::Finite_faces_iterator fit = sdg.finite_faces_begin();
for( ; fit != sdg.finite_faces_end(); fit++)
SDG2::Face_handle v = fit;
//where are the reference in the manual for the face handle?
//what am i supposed to do now with v to get all the vertices of the face?
For example :
On Sun, Jul 19, 2009 at 3:51 AM, Sylvain Pion <> wrote:
wrote:There has been some renaming of these classes since CGAL 3.1
Hello, I need the voronoi diagram of a geometric 2D shape in order to calculate its
medial axis. So I was going through the CGAL manual, precisely at :
http://www.cgal.org/Manual/3.1/doc_html/cgal_manual/Segment_Voronoi_diagram_2/Chapter_main.html
and I figured out that i do not have the following headers: - Segment_Voronoi_diagram_filtered_traits_2.h
- Segment_Voronoi_diagram_hierarchy_2.h
I installed CGAL 3.3.1 using the windows installer and I am running it on Vista
x64 with VS2008.
(it's now Segment_Delaunay_*graph*_2), so you should use
the manual corresponding to the version of CGAL that you use.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] 2D Segment Voronoi Diagrams, fedeperazzi, 07/19/2009
- Re: [cgal-discuss] 2D Segment Voronoi Diagrams, Sylvain Pion, 07/19/2009
- Re: [cgal-discuss] 2D Segment Voronoi Diagrams, Federico Perazzi, 07/20/2009
