cgal-discuss - [cgal-discuss] Merge performance for large number of polygons/sides
  • To:
  • Subject: [cgal-discuss] Merge performance for large number of polygons/sides
  • Date: Thu, 23 Jul 2009 21:02:03 -0400
Hi Y'all,
Looking at the boolean operations code, it seems to me that if I am joining a large number of polygons and they have a large number of sides and the number of intersecting areas is small, the merge is going to be slower than necessary because the polygons are merged pair-wise in a merge sort.
This means O(log N) sweeps over the entire set of edges...where N is the number of input polygons. If the number of input polygons is large and the number of edges is large, my sweep time goes up.
I'm wondering if it is possible to implement a single-pass sweep algorithm...basically:
- Sweep every single line segment together once into one big arrangement.
- Traverse the arrangement once, determining the "contained" state of each face using a breadth-first search.
Basically each time I cross an edge in the arrangement, I would need to update a "depth" count to track whether I am inside one or more polygons...any face whose depth > 0 is in.
Is there any reason why this would not work, or why the performance would be worse than the existing merge?
cheers
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
