cgal-discuss - Re: [cgal-discuss] Assertion failure inserting curves - sweep bug?
  • To:
  • Subject: Re: [cgal-discuss] Assertion failure inserting curves - sweep bug?
  • Date: Tue, 28 Jul 2009 12:20:23 +0300
Quoting "Ben Supnik"
Hi Efi,
Foo - I can't reproduce the problem. My old code was based on building the map out of a series of boolean operations...because of the poor performance of this structure, I rewrote the code a few days ago to do a single massive insert_curves, and the map as it is built now won't fail with the addition sweep visitor.
I guess this is good.
I think the most likely problem is that I violated some kind of precondition requirement for the boolean operations code, resulting in an illegal shortcut in the boolean ops that produced a bogus map. :-( The map would pass is_valid but perhaps that test isn't conclusive?
Having a small program that reproduces a bug is the only way we are prepared to deal with bugs now days, so if it re-occurs, I'll be happy to debug a small test case.
The is_valid() function might be non conclusive. I would call it a bug, perhaps not a critical one. If you are able to produce an invalid arr. that is not caught by the is_valid() function, let us know.
cheers
Ben
Efraim Fogel wrote:
Ben Supnik wrote:
Hi Y'all,
I have an arrangement (built out of join and difference operations on polygons). I am using an exact pred/exact constructions kernel and half -frounding-math on. I am in debug mode, so I have all warnings, etc.
After building my arrangement, I do an insert-curves on an axis-aligned bounding box that sometimes overlaps the horizontal and vertical edges of my map.
If I insert the four sides using insert_curve, all is good.
If I insert all four using insert_curves, I get an assertion failure when trying to split a face.
Now...looking at the code it seems clear that I should be using insert_curve anyway; doing a full copy of the arrangement to put only four curves in will be dominated by the copy cost.
There are cases where applying incremental inserts is more efficient than an applying an aggregate insert, especially when the number if input curves is small, but which copy of arrangement do you refer to?
But...is there any case where the sweep-line-based insert_curves should blow up? I am concerned that either my map is secretly invalid (it passes validation checks) or I have compiler settings such that my numerics are not stable.
We are not aware of any bug of that sort. Try to come up with a test case that exposes the problem, and that we can reproduce, and we'll look at it.
cheers
ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
