- To:
- Subject: Re: [cgal-discuss] Access to edge
- Date: Tue, 28 Jul 2009 15:55:25 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=imALhQtPQ0mv51GKgfsuLYW/Ldt/JgyuWn3h+Qhz/UaK+lvMl3xd0TnEJzMu2lV9rV lINey2UqiEpCtMzYNjxa9I2wsEg0VZWfpMTEkhKhkhM3MvfrnOcMgdbLII3Pzjit7TA5 ipfZRy+EmxKS0ih51wg57sB2/1qbfp0uIPq7w=
Thank you.
How about first part of my questions: how to get edge from 2 vertices?
And do you know time complexity of function t.is_edge ?
On Tue, Jul 28, 2009 at 3:42 PM, Olivier Devillers <> wrote:
400555 a écrit :looking at the manual is often useful !
Hello.
Let us suppose that we have Delaunay 2D triangulation.
How to get edge from it if I know 2 vertices ?
And how to check if there is an edge in triangulation between these two vertices?
Thank you.
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Cross_link_anchor_1166
bool t.is_edge ( Vertex_handle va, Vertex_handle vb)
true if there is an edge having va and vb as vertices.
- [cgal-discuss] Access to edge, 400555, 07/28/2009
- Re: [cgal-discuss] Access to edge, Olivier Devillers, 07/28/2009
- Re: [cgal-discuss] Access to edge, 400555, 07/28/2009
- Re: [cgal-discuss] Access to edge, Manuel Caroli, 07/28/2009
- [cgal-discuss] Straight_skeleton_2, hans.maes, 07/29/2009
- Re: [cgal-discuss] Straight_skeleton_2, Fernando Cacciola, 07/29/2009
- [cgal-discuss] example asp.net, hans.maes, 07/28/2009
