- To:
- Subject: Re: [cgal-discuss] Access to edge
- Date: Tue, 28 Jul 2009 17:30:41 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=rh4sBqRAGbaUD8u57uVeevnxZQ2RWatmwMi605nxjJ4UlBlaZ0+SWiDKaKJhO+VXkT 9ZaSnvPCJiCEVPU+VFhp8UIAwsMIc1zozECtvFns18jZzidS6uLFTSrKk5MirQhlW/nm MiPLh+ztENa/SjodJW/Sa3HyEw3XOif3K04jo=
Thank you! That what I need.
And what does it mean: complexity is O(deg(va))?
deg(va) - is number of edges from vertex va ?
So the complexity is O(const) isn't it ?
On Tue, Jul 28, 2009 at 4:26 PM, Manuel Caroli <> wrote:
Hi 400555,
I can only repeat what Olivier was saying. Maybe the following function (which is documented at the same place) might be more helpful to you:
bool t.is_edge ( Vertex_handle va, Vertex_handle vb, Face_handle& fr, int & i)
as above. In addition, if true is returned, the edge with vertices va and vb is the edge e=(fr,i) where fr is a handle to the face incident to e and on the right side of e oriented from va to vb.
The worst case complexity is O(deg(va))
best
Manuel
400555 wrote:
Thank you.
How about first part of my questions: how to get edge from 2 vertices?
And do you know time complexity of function t.is_edge ?
On Tue, Jul 28, 2009 at 3:42 PM, Olivier Devillers < <mailto:>> wrote:
400555 a écrit :
Hello.
Let us suppose that we have Delaunay 2D triangulation.
How to get edge from it if I know 2 vertices ?
And how to check if there is an edge in triangulation between
these two vertices?
Thank you.
looking at the manual is often useful !
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Cross_link_anchor_1166
bool t.is_edge ( Vertex_handle va, Vertex_handle vb)
true if there is an edge having va and vb as vertices.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Access to edge, 400555, 07/28/2009
- Re: [cgal-discuss] Access to edge, Olivier Devillers, 07/28/2009
- Re: [cgal-discuss] Access to edge, 400555, 07/28/2009
- Re: [cgal-discuss] Access to edge, Manuel Caroli, 07/28/2009
- [cgal-discuss] Straight_skeleton_2, hans.maes, 07/29/2009
- Re: [cgal-discuss] Straight_skeleton_2, Fernando Cacciola, 07/29/2009
- [cgal-discuss] example asp.net, hans.maes, 07/28/2009
