- To: <>
- Subject: RE: [cgal-discuss] About polyhedra(polyhedron_prog_cube.cpp)
- Date: Wed, 29 Jul 2009 10:29:07 +0800
- Importance: Normal
Sorry, I typed the wrong title (polyhedron_prog_cube.cpp) Thanks From: To: Date: Wed, 29 Jul 2009 09:28:48 +0800 Subject: [cgal-discuss] About polyhedra(polyhedron_prog_off.cpp) Hi All, I am confused about Polyhedra edges, and found it difficult to manipulate. 1. I created a project including examples/Polyhedron/polyhedron_prog_cube.cpp, build and run, the result of P.is_tetrahedron(h) is false. Is the fact true? Are the figures in the manual(P1488) right? 2. In P1513, said "The opposite() member function returns this halfedge of opposite orientation." I edit the below code: CGAL_precondition( P.is_valid()); typedef Polyhedron::Point_3 Point; typedef Polyhedron::Halfedge_handle Halfedge_handle; Halfedge_handle h = P.make_tetrahedron( Point( 1, 0, 0), &nb sp; Point( 0, 0, 1), Point( 0, 0, 0), Point( 0, 1, 0)); Halfedge_handle g = h->next()->opposite()->next(); // Fig. (a) std::cout << "h" << std::endl; std::cout << h->vertex()->point() << std::endl; std::cout << h ->next()->vertex()->point() << std::endl; std::cout << std::endl; std::cout << "h opposite" << std::endl; Halfedge_handle ho = h->opposite(); std::cout << ho->vertex()->point() << std::endl; std::cout << ho->next()->vertex()->point() << std::endl; std::cout << std::endl; The result is: h 1 0 0 0 0 1 h opposite 0 0 0 0 1 0 It seems h opposite is not h of opposite orientation. Did I misunderstand something? 3. Is there any other way to construct a polyhedra or 3D surface? Thanks See all the ways you can stay connec ted to friends and family What can you do with the new Windows Live? Find out |
- [cgal-discuss] About polyhedra(polyhedron_prog_off.cpp), gang wang, 07/29/2009
- RE: [cgal-discuss] About polyhedra(polyhedron_prog_cube.cpp), gang wang, 07/29/2009
