cgal-discuss - RE: [cgal-discuss] About polyhedra(polyhedron_prog_cube.cpp)
  • To: <>
  • Subject: RE: [cgal-discuss] About polyhedra(polyhedron_prog_cube.cpp)
  • Date: Wed, 29 Jul 2009 14:44:38 +0800
  • Importance: Normal
I know where my mistake is.
The two points of a halfedge is h->previous->vertex() and h->vertex(), not h->vertex() and h->next()->vertex()
I know how polyhedron_prog_cube.cpp works now.
Is there any suggestion to create a surface(solid object) using triangles?
Thanks
To:
Date: Wed, 29 Jul 2009 13:42:06 +0800
I know the result of P.is_tetrahedron(h) should be false.
Now the remaining questions are:
Are the figures in the manual(P1488) right?
Does h->opposite() have the same vertices with h? Why in my test program(below in the first email) they are different four points?
Thanks
To:
Date: Wed, 29 Jul 2009 10:29:07 +0800
Sorry, I typed the wrong title (polyhedron_prog_cube.cpp)
Thanks
To:
Date: Wed, 29 Jul 2009 09:28:48 +0800
Subject: [cgal-discuss] About polyhedra(polyhedron_prog_off.cpp)
Hi All,
I am confused about Polyhedra edges, and found it difficult to manipulate.
1. I created a project including examples/Polyhedron/polyhedron_prog_cube.cpp, build and run, the result of P.is_tetrahedron(h) is false. Is the fact true?
2. In P1513, said "The opposite() member function returns this halfedge of opposite orientation."
    I edit the below code:
    CGAL_precondition( P.is_valid());
    typedef Polyhedron::Point_3         Point;
    typedef Polyhedron::Halfedge_handle Halfedge_handle;
    Halfedge_handle h = P.make_tetrahedron( Point( 1, 0, 0),
                                  &nb sp;         Point( 0, 0, 1),
                                            Point( 0, 0, 0),
                                            Point( 0, 1, 0));
    Halfedge_handle g = h->next()->opposite()->next();             // Fig. (a)
    std::cout << "h" << std::endl;
    std::cout << h->vertex()->point() << std::endl;
    std::cout << h ->next()->vertex()->point() << std::endl;
    std::cout << std::endl;
    std::cout << "h opposite" << std::endl;
    Halfedge_handle ho = h->opposite();
    std::cout << ho->vertex()->point() << std::endl;
    std::cout << ho->next()->vertex()->point() << std::endl;
    The result is:
    h
    1 0 0
    0 0 1
    h opposite
    0 0 0
    0 1 0
    It seems h opposite is not h of opposite orientation.
    Did I misunderstand something?
3. Is there any other way to construct a polyhedra or 3D surface?
Thanks
See all the ways you can stay connec ted to friends and family
What can you do with the new Windows Live? Find out
