- To:
- Subject: Re: [cgal-discuss] Wrong mirror vertex
- Date: Wed, 29 Jul 2009 15:15:43 +0200
400555 wrote:
Dear Manuel, thank you for answer!checks whether the faces are well oriented (counterclockwise I think).
Could you please tell me what is 1) "validity of the geometric embedding (orientation of faces)"
2) "combinatorial validity"checks e.g. whether a vertex is a vertex of the face it points to, whether the neighboring relation is coherent and so on.
see above. Crossing edges will yield faces of wrong orientation.
I figured out that my triangulation becomes not valid after my first flip, for both cases: Delaunay_triangulation_2 and Triangulation_2. And I don't understand why.
As I understand triangulation if it is not Delaunay could be not valid if some edges cross, and for Delaunay additional check for circle criteria, anything else?
It would be helpful if you could see the documentation:
>> This is guaranteed only if the precondition is fulfilled. You should compile your code in debug mode, then the preconditions will be tested for explicitly.
What do you mean "precondition is fulfilled" ?
void t.flip ( Face_handle f, int i) Exchanges the edge incident to f and f->neighbor(i) with the other diagonal of the quadrilateral formed by f and f->neighbor(i).
Precondition: The faces f and f->neighbor(i) are finite faces and their union form a convex quadrilateral.
If you compile your code in debug mode it will abort with an error message if you call flip while the preconditions are not fulfilled (as I wrote before).
You'll have to browse trough the Parts I-III of the manual. I think you should have a more thorough look on chapters 1, 4 and especially 7.
Also, could you please say in easy words what does it mean: exact \ inexact predicates \ constructions ?
I read manual but didn't find explanation, maybe because of my hurry.
For triangulations you should be well off using the predefined Exact_predicates_exact_constructions_kernel.
no. How do you print it?
And also a small questions. When I print vertex->point() - I see something like (2; 3) when really it should be (1,8799; 2,789). Do you know why?
You should try to find the problem in your code with the tools I told you. As I don't see your code, and neither have the time to debug it, I'm afraid I cannot be too helpful answering questions like "why doesn't it work".
Sorry for many questions. I will very appreciate if you answer them.
Good luck!
Manuel
Thank you.
On Wed, Jul 29, 2009 at 1:05 PM, Manuel Caroli < <mailto:>> wrote:
Hi,
400555 wrote:
So, In the beginning I have correct Delaunay. Then after several
flipping I get that is_valid() != 1. By the way what exactly
validity is_valid() function checks? If Delaunay - I don't need it.
1) The Delaunay_triangulation_2::is_valid() checks the Delaunay
property.
2) Triangulation_2::is_valid() checks the validity of the geometric
3) Triangulation_data_structure_2::is_valid() checks combinatorial
validity.
1 does not apply to you. 2 calls 3 so I would recommend you to use 2.
All this is described in the documentation btw.
If it checks for not edge crossing etc - then how is it possible
that I am getting not valid structure after applying several
T.flip(f, i), in manual I see that this function "guaranteed to
lead to a valid triangulation".
About "square perimeter of a vertex" I meant that I have square
border of my domain, all points lie inside of this square and
also some of them on the border (so in fact on the sane line).
If you use an exact predicates kernel degenerate cases will be
treated correctly.
Do you have any idea what could be wrong?
Still no because I don't know what your code is doing ;-) These are
just hints that are supposed to help you debug your code.
Manuel
Thank you.
On Wed, Jul 29, 2009 at 11:00 AM, Manuel Caroli
<mailto:>
<mailto:
<mailto:>>>
wrote:
Dear 400555,
400555 wrote:
Hello !
Could you please help with my problem.
I make Delaunay_2 for set of points.
Then, on each iteration I change positions of point and
accordingly to my criteria do Flip of some edges (only
for finite).
(and I checked that new edge obtained after flipping also
stand
finite)
Note that as soon as you change point coordinates or do flips
manually the triangulation is most probably not Delaunay
anymore. So
there are no guarantees anymore about the behavior of e.g. the
insert function.
After somewhile I find that for one edge vertex(i) and vertex
which is mirror_vertex to it - become the same.
Do you know how is it possible?
no, because I don't know what your code is doing. You might
want to
use the is_valid() functions from Triangulation_2 and
Triangulation_data_structure_2 to check whether you still have a
valid triangulation after each of your modifications.
There is a part of my code below. ov1 becomes equal to ov2.
Someone knows why?
Your code below does not modify the triangulation. I suppose the
error occurs already during modification. See above.
Can the fact that I have also square perimeter of vertices
(which are lie on the line) be affected to this problem?
I'm sorry I don't understand this one. What do you mean by the
square perimeter of a vertex?
About your question before about edge with info: As edges are not
represented explicitly there is no possibility to store some info
with it. However you could store the info in one of the incident
faces, then you can look it up in constant time.
best
Manuel
for (Finite_edges_iterator2 eit = T.finite_edges_begin();
eit !=
T.finite_edges_end(); ++eit)
Edge2 ed = *eit;
Face_handle2 f = ed.first;
int i = ed.second;
Vertex_handle2 vh1 = f->vertex(T.cw(i));
Vertex_handle2 vh2 = f->vertex(T.ccw(i));
if ((f->vertex(i) != T.infinite_vertex()) &&
(f->mirror_vertex(i) != T.infinite_vertex()))
ov1 = f->vertex(i)->info();
ov2 = T.mirror_vertex(f, i)->info();
Thank you.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Wrong mirror vertex, 400555, 07/28/2009
- Re: [cgal-discuss] Wrong mirror vertex, Manuel Caroli, 07/29/2009
- Re: [cgal-discuss] Wrong mirror vertex, 400555, 07/29/2009
- Re: [cgal-discuss] Wrong mirror vertex, Olivier Devillers, 07/29/2009
- Re: [cgal-discuss] Wrong mirror vertex, 400555, 07/31/2009
