cgal-discuss - [cgal-discuss] Wrong mirror vertex
  • To:
  • Subject: [cgal-discuss] Wrong mirror vertex
  • Date: Tue, 28 Jul 2009 22:44:06 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=JK0z0+/vVe9a6DQRpwXo7Wz0ifAsH1LoGVZDjzsKNtkDRCvZoUciQ2H9/R6E8X8MMf hkfh/dpKTgYbySFfExuHggtwVa2uej6126qM4f1rUnskT6LD32gDfd9cTG8g4ziQ0LHI Ckxw2TKR71kC3gym47/y34a2zF9uAd+hfK60A=
Hello !
Could you please help with my problem.
I make Delaunay_2 for set of points.
Then, on each iteration I change positions of point and accordingly to my criteria do Flip of some edges (only for finite).
(and I checked that new edge obtained after flipping also stand finite)
After somewhile I find that for one edge vertex(i) and vertex which is mirror_vertex to it - become the same.
Do you know how is it possible?
There is a part of my code below. ov1 becomes equal to ov2. Someone knows why?
Can the fact that I have also square perimeter of vertices (which are lie on the line) be affected to this problem?
for (Finite_edges_iterator2 eit = T.finite_edges_begin(); eit != T.finite_edges_end(); ++eit)
     Edge2 ed = *eit;
     Face_handle2 f = ed.first;
     int i = ed.second;
     Vertex_handle2 vh1 = f->vertex(T.cw(i));
     Vertex_handle2 vh2 = f->vertex(T.ccw(i));
     if ((f->vertex(i) != T.infinite_vertex()) && (f->mirror_vertex(i) != T.infinite_vertex()))
          ov1 = f->vertex(i)->info();
          ov2 = T.mirror_vertex(f, i)->info();
Thank you.
