- To:
- Subject: Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3.
- Date: Wed, 5 Aug 2009 11:10:49 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=CzBRotblGQAO7Op+x/CZBRWF9zUoMmE5OGxCbhX3W1Dx/4g9tepqWCphaprKgPDJmQ rAUKZLf/y+3aULa/1UITvJp1tevyOsDC1btU5NMpUAyocmPMuhEACfOVGz5vRIC8OPx8 iCzpAI/4O9cfVffzIQ7Pz6W5ItWohs/Jmy+sc=
Hello again Manuel,
Yes. By "surface" I was refearring to the convex hull (the outter side of the envelop points).
This new package for "Surface reconstruction" seems just GREAT.
It looks exactlly what I need to do.
I'm going to download the beta version to test it now!
Just one more thing:
I was trying to to integrate the alpha shape with my current example.
Right now I have CGAL::Triangulation_vertex_base_with_info_3 in order to set the ->info() with my
index.
For the alpha shape, If I really understood it, I must use CGAL::Alpha_shape_vertex_base_3 but this does not contain
the "info" field.
Is there any other way for me to set the "info"?
There should be an CGAL::Alpha_shape_vertex_base_with_info_3 file to do so, right?!
Thanks a lot again,
Best regards,
Juliano.
2009/8/5 Manuel Caroli <>
Hi Juliano,
Juliano Costa wrote:
Hello Manuel,[...]
The *interior* of the (smallest) sphere passing through the two vertices of the diagonal of a cube (or cuboid) does not contain any other vertices of the cube (or cuboid). This is a degenerate case though. The CGAL::Triangulation_3 partitions the convex hull of the point set into tetrahedra even in degenerate cases. So the result you get is fine.I don't actually get what you mean by "surface" in the code below. Are you talking about the convex hull?
Well, I ignored this issue and proceed with my intend so I used the DelaunayTriangleHierarchy::Finite_facets_iterator like this:
Yes the surface mesher creates its own points so it does not seem adapted to your problem.
//On inserting points I'm setting the Vertex_hanlde->info with an "unsigned long" value as index. //I need to get the triangles points indexes:
CPUInt64_t _indexA,_indexB,_indexC;
CPUInt64_t* _iPointsIndexes[3];
_iPointsIndexes[0] = &_indexA;
_iPointsIndexes[1] = &_indexB;
_iPointsIndexes[2] = &_indexC;
//having DelaunayTriangleHierarchy _delaunayTrianguleHierarchy;
DelaunayTriangleHierarchy::Finite_facets_iterator _fit = _delaunayTriangule.finite_facets_begin(); while(_fit != _delaunayTriangule.finite_facets_end())
//typedef CGAL::Delaunay_triangulation_3<K,Tds> DelaunayTriangle;
DelaunayTriangle::Facet _facet = *_fIt;
unsigned long _facetIndex = _facet.second;
//typedef DelaunayTriangle::Cell_handle CGALCellHandle;
CGALCellHandle facetCell = _facet.first;
char _isInfiniteCell = _delaunayTriangule->is_infinite(_facetCell);
//neighbor cell
CGALCellHandle neigborCell = _cell->neighbor(_facetIndex );
char _isInfiniteNeigbor = _delaunayTriangule.is_infinite(neigborCell);
if( (!_isInfiniteCell) && (!isInfiniteNeigbor) )
//I only want the surface right?!?!!
continue;
} char _iTriVrr=0;
for(char _iPointsLoop=0;_iPointsLoop<4;_iPointsLoop++)
if( _iPointsLoop != _facetIndex )
*_iPointsIndexes[_iTriVrr++] = (unsigned long)(_fIt->first->vertex(_iPointsLoop)->info());
//Here I got _indexA,_indexB,_indexC which I'm saving on the OBJ file.
_fit++;
} With this code, when I provide an ordinary box or even a sphere the result is just wonderful.
But when I try this with a small points cloud (10000 3d points of a tunnel for example) the result is a mess.
I got triangles coming from a side to the another and from the top to the ground.
I want just the surface.
I used this tunnel points cloud as example, but my intention is to use the same algorith providing points cloud of any
3d object or place (e.g.: an office room).
Now I was about to try to integrate the my current source code with the CGAL "alpha shape" example...
But you've come with a different "light": "use a surface mesher". But a surface mesher wouldn't interpolate "new created points"?
You might want to have a look at the new Surface reconstruction package: http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.htmlSo, to make this "surface mesher" what I've be doing so far is useless?<http://www.cgal.org/Manual/3.3/examples/Surface_mesher/mesh_an_implicit_function.cpp>the input points comes from a generator surface function // defining the surface
On the CGAL examples for surface mesher (like examples/Surface_mesher/mesh_an_implicit_function.cpp)
// Surface_3 <http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesher_ref/Concept_Surface_3.html#Cross_link_anchor_1083> surface
Can I insert points of an unknown shape?
Note that this is only a beta release. The final release will be available by mid September.
best
Manuel
I really appreciate your help!2009/8/5 Manuel Caroli < <mailto:>>
Thanks once again!
Juliano Costa
Brazil.
Hi Juliano,
the Triangulation_3 package computes a triangulation of R^3 with the
input points as vertices. If you want to compute a triangular mesh
approximating a surface you should use a surface mesher. Maybe you
could be more specific about your problem.
best
Manuel
- [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/01/2009
- [cgal-discuss] Re: Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/02/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Mariette Yvinec, 08/03/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/03/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Manuel Caroli, 08/05/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/05/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/07/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Manuel Caroli, 08/10/2009
