- To:
- Subject: Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3.
- Date: Fri, 7 Aug 2009 14:51:14 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=exbuVYT/OvkWo3IEEqhsYJSwlemAr5klbhN2GYiBCWw0eCFwg+UMiVWZKGDE8oYGk4 sCQc2s4eQmrKSBrhQZ69sIW9zQJl4dhBzBynZ5gmgNg1eZqSQH6MBWV7nozZeRSSdow9 ffTkGtQiPMpVyMwOsTn5rYVLtq8ugwI5KGwDU=
Hello Manuel,
Some additional issues:
1. About Alpha Shapes:
- As you suggested I tried to do something nested in order to set my ->info() information along with the added vertices.
My used declaration is like this:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
//My info is just a ordered index for the vertices
typedef CGAL::Triangulation_vertex_base_with_info_3<CPUInt64_t, K> Vbi;
typedef CGAL::Alpha_shape_vertex_base_3<K,Vbi> AsVbi;
typedef CGAL::Alpha_shape_cell_base_3<K> AsCb;
typedef CGAL::Alpha_shape_3<DelaunayTriangleHierarchy> Alpha_shape_3;
typedef Alpha_shape_3::Alpha_iterator Alpha_iterator;
typedef Alpha_shape_3::NT NT;
Then I got these errors:
error C2039: 'set_down' : is not a member of 'CGAL::Alpha_shape_vertex_base_3<Gt,Vb>'
error C2039: 'set_up' : is not a member of 'CGAL::Alpha_shape_vertex_base_3<Gt,Vb>'
Am I doing anything wrong about your suggestion?!
I didn't understang why if I use "incident_cells(infinite_vertex(), output_iterator)" I wouln't
need the index any longer.
I'm using this ->info to set the index, so after the triangulation the indexes of the vertices
are the same as when I add it, since after the insertion the initial order is not guaranteed,
right?! So I guess this info is fundamental. Or not???
2. About the Surface Reconstruction:
- The Surface Reconstruction seems to be great for any kind of points cloud but
I have a point cloud with x,y,z only (not the normals) and then I tried to use the
example "..\examples\Point_set_processing_3\normal_estimation" to calculate
the necessary oriented normals for the Poisson reconstruction.
I'm trying to use it on a x,y,z file of a points cloud with 50000 points and the
program is freezing on the second fase (normals orientation). See the output
of the program:
tunnel_50mil.xyz tunnel_50mil_normals.xyz
Normal estimation
Open tunnel_50mil.xyz for reading...
Reads file tunnel_50mil.xyz: 50000 points, 2.496 seconds
Estimates Normals Direction by Jet Fitting (k=18)...
Calls jet_estimate_normals()
6 Mb allocated
Creates KD-tree
11 Mb allocated
Computes normals
14 Mb allocated
End of jet_estimate_normals()
done: 52.405 seconds, 7 Mb allocated
Orients Normals with a Minimum Spanning Tree (k=18)...
Calls mst_orient_normals()
7 Mb allocated
Create Index_property_map
Index_property_map: optimized version for a random access container
mst_find_source()
7 Mb allocated
Creates KD-tree
13 Mb allocated
Creates Riemannian Graph
//From here (...) Never finishes!
Normal estimation
6 Mb allocated
Creates KD-tree
11 Mb allocated
Computes normals
14 Mb allocated
7 Mb allocated
mst_find_source()
7 Mb allocated
Creates KD-tree
13 Mb allocated
Thanks a lot for all your help!
Juliano Costa
2009/8/5 Manuel Caroli <>
Hi Juliano,
Juliano Costa wrote:Note that you can useHello again Manuel,
Yes. By "surface" I was refearring to the convex hull (the outter side of the envelop points).
incident_cells(infinite_vertex(), output_iterator) to get the cells that have the triangles of the convex hull as a facet.It should be possible to use them in a nested way, i.e.
This new package for "Surface reconstruction" seems just GREAT.
It looks exactlly what I need to do.
I'm going to download the beta version to test it now!
Just one more thing:
I was trying to to integrate the alpha shape with my current example.
Right now I have CGAL::Triangulation_vertex_base_with_info_3 in order to set the ->info() with my
index.
For the alpha shape, If I really understood it, I must use CGAL::Alpha_shape_vertex_base_3 but this does not contain
the "info" field.
Is there any other way for me to set the "info"?
There should be an CGAL::Alpha_shape_vertex_base_with_info_3 file to do so, right?!
Alpha_shape_vertex_base_3<Traits,Triangulation_vertex_base_with_info_3>
Maybe with the above mentioned approach to extract the convex hull you don't need the info anymore...
best
Manuel
- [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/01/2009
- [cgal-discuss] Re: Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/02/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Mariette Yvinec, 08/03/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/03/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Manuel Caroli, 08/05/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/05/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Juliano Costa, 08/07/2009
- Re: [cgal-discuss] Newbie question about CGAL Hierarchy Triangulation 3., Manuel Caroli, 08/10/2009
