- To:
- Subject: [cgal-discuss] Triangle_3_Segment_3_intersection question
- Date: Mon, 10 Aug 2009 22:17:38 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=l8ViONyDuMfGvmf6CvAg9SCXNeyHiTkqEK7N36XduKhiAQtvp9vGhrSn1B/Lv7Kv9w DXYMmp00qrfy1BrtBfsD8oHWztK2JD43RajT1bQ8T5BVVXsvBKcfRe8dSoczT3gOUFZH bbINeNN1rf5//zXZp21ctUp9qIGFGzO5v2MDc=
Hello,
I have a question regarding the Triangle_3_Segment_3_intersection function that is in CGAL3.5b1. Should it ever return a degenerate Segment_3? Seems like it should return a Point_3 instead. Not sure if this is a bug, is the intended behavior, or I am doing something wrong.
The situation that is giving me the degenerate segment is the intersection of a coplaner triangle and segment where the end of the segment is touching the edge of the triangle.
I can send a simple example if anyone is interested.
Thanks,
Matt
- [cgal-discuss] Triangle_3_Segment_3_intersection question, Matthew Denno, 08/11/2009
- [cgal-discuss] Fwd: Triangle_3_Segment_3_intersection question, Matthew Denno, 08/12/2009
- Re: [cgal-discuss] Fwd: Triangle_3_Segment_3_intersection question, Pierre Alliez, 08/13/2009
- Re: [cgal-discuss] Fwd: Triangle_3_Segment_3_intersection question, Matthew Denno, 08/13/2009
- Re: [cgal-discuss] Fwd: Triangle_3_Segment_3_intersection question, Matthew Denno, 08/20/2009
