cgal-discuss - [cgal-discuss] Fwd: Triangle_3_Segment_3_intersection question
  • To:
  • Subject: [cgal-discuss] Fwd: Triangle_3_Segment_3_intersection question
  • Date: Wed, 12 Aug 2009 11:59:36 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=nKp5eVAdurCz5FrlSKb0DNrn4OBmlMDs6nbIxSwzxt18Q8qyG+4sh9rUbrgtZhn/MV r1p1vshq2L4dB/k7voWkZ+6Hu7pTRQj5/O7HnniwTcZ9D/Ms3ivuZuEn4CxsrsS3S5BI XMngAi1K3f22gOBxqoCqf5fF0OfckPP1EPjZo=
Hi All,
So I have implemented a solution for my question below.  If the object returned is a segment I check to see if it is degenerate.  If it is I convert its source end to a point.  This seems to work ok.  However, I am still interested to know if this is the intended behavior or not?  Anyone have any thoughts?
Regards,
Matt
---------- Forwarded message ----------
Date: Mon, Aug 10, 2009 at 10:17 PM
Subject: Triangle_3_Segment_3_intersection question
To:
Hello,
I have a question regarding the Triangle_3_Segment_3_intersection function that is in CGAL3.5b1.  Should it ever return a degenerate Segment_3?  Seems like it should return a Point_3 instead.  Not sure if this is a bug, is the intended behavior, or I am doing something wrong.
The situation that is giving me the degenerate segment is the intersection of a coplaner triangle and segment where the end of the segment is touching the edge of the triangle.
I can send a simple example if anyone is interested.
Thanks,
Matt
