- To:
- Subject: Re: [cgal-discuss] Regular triangulation with info
- Date: Tue, 11 Aug 2009 19:53:59 +0200
Dear 400555,
please have a look in the documentation before you write to the list.
I cite from the reference documentation of Regular_triangulation_3:
"The second template argument must be a model of the TriangulationDataStructure_3 concept. It has the default value Triangulation_data_structure_3<Triangulation_vertex_base_3<RegularTriangulationTraits_3>, Regular_triangulation_cell_base_3<RegularTriangulationTraits_3> >."
and the reference documentation of Triangulation_vertex_base_with_info_3:
"The class Triangulation_vertex_base_with_info_3 is a model of the concept TriangulationVertexBase_3, the base vertex of a 3D-triangulation. It provides an easy way to add some user defined information in vertices."
Followingly, you can use the Triangulation_vertex_base_with_info_3 in exactly the same way as for Delaunay_triangulation_3.
best
Manuel
400555 wrote:
Hello everyone !
Is it possible to have weighted Delaunay triangulation with info with using CGAL ?
And am I correct that CGAL regular triangulation of a set of weighted points gives me weighted Delaunay ? ...but how to add info to it, I don't know
Can you help me, please?
Thank you.
- [cgal-discuss] Regular triangulation with info, 400555, 08/11/2009
- Re: [cgal-discuss] Regular triangulation with info, Manuel Caroli, 08/11/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/12/2009
- Re: [cgal-discuss] Regular triangulation with info, Sebastien Loriot, 08/12/2009
- Re: [cgal-discuss] Regular triangulation with info, Manuel Caroli, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, Sylvain Pion, 08/13/2009
- [cgal-discuss] Delaunay triangulation 3, Sebastien Loriot, 08/13/2009
- Re: [cgal-discuss] Delaunay triangulation 3, Sebastien Loriot, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/13/2009
