- To:
- Subject: Re: [cgal-discuss] Regular triangulation with info
- Date: Thu, 13 Aug 2009 11:10:03 +0200
Hi,
the weighted Delaunay triangulation has some additional overhead due to points that can be hidden. If you have a lot of hidden points this might have a considerable effect on running times. Also maybe you profit from some optimizations in Delaunay triangulation but not in the weighted Delaunay triangulation.
Without more information about your problem and your code and I cannot tell you more than the above speculations.
best
Manuel
400555 wrote:
Hello !
Could you say your opinion about:
I tried to compare performance between using CGAL Delaunay and Regular triangulation with weighted points.
I rebuilt it 200.000 times for moving points (I know that rebuilding is not best option) and Delaunay takes 17 sec but weighted one - 64 seconds.
I don't understand why, difference is only that weighted one considers about weight which is included in determinant (which defines "in circle" criteria), please correct me if I am wrong.
So I was not expected so much time difference between them.
Do you know why it happen?
Thank you.
On Wed, Aug 12, 2009 at 7:02 PM, 400555 < <mailto:>> wrote:
Dear Sebastien, thank you very much!
Now it works!
On Wed, Aug 12, 2009 at 6:50 PM, Sebastien Loriot
<mailto:>>
wrote:
Hello,
The vertex type you are using is for triangulation.
You should use CGAL::Regular_triangulation_vertex_base_2 instead.
Then to add info you can follow what is done for the case of the
triangulation of point in
Triangulation_vertex_base_with_info_2.h
S.
<http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_2_ref/Class_Regular_triangulation_vertex_base_2.html#Cross_link_anchor_1161>
400555 wrote:
Dear Manuel,
thank you for help!
Now I have problem, when I am trying to insert points.
I do it like this:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Regular_triangulation_filtered_traits_2<K> Traits;
typedef CGAL::Triangulation_vertex_base_with_info_2<int, K> Vb;
typedef CGAL::Regular_triangulation_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
typedef CGAL::Regular_triangulation_2<Traits, Tds> RegularTr;
typedef K::Point_2 Point;
typedef RegularTr::Weighted_point WPoint;
RegularTr T;
WPoint wp(Point(1,2), 2);
T.insert(wp); // If delete this line - no compiler errors !!!
I tried to modify type of Kernel and way how I define
Weighted_point, but it doesn't work
Could you please help me?
/usr/bin/c++ -frounding-math -O3 -DNDEBUG
-I/storage/usr/people/400555/MD
-I/storage/usr/people/400555/CGAL-3.4/include -o
CMakeFiles/main.dir/main.o -c
/storage/usr/people/400555/MD/main.cpp
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:
In member function 'void CGAL::Regular_triangulation_2<Gt,
Tds>::hide_vertex(typename
CGAL::Triangulation_2<CGAL::Weighted_point_mapper_2<Gt>,
Tds>::Face_handle, typename
Tds>::Vertex_handle) [with Gt =
CGAL::Regular_triangulation_filtered_traits_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, Tds =
CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<int,
CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,
CGAL::Triangulation_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>, CGAL::Triangulation_ds_vertex_base_2<void> > >,
CGAL::Regular_triangulation_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Triangulation_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>, CGAL::Triangulation_ds_face_base_2<void> > > >]':
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:1082:
instantiated from 'typename
CGAL::Regular_triangulation_2<Gt, Tds>::Vertex_handle
CGAL::Regular_triangulation_2<Gt, Tds>::insert(const
typename Gt::Weighted_point_2&, typename
Tds>::Locate_type, typename
Tds>::Face_handle, int) [with Gt =
> >, Tds =
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:1050:
Tds>::Face_handle) [with Gt =
> >, Tds =
/storage/usr/people/400555/MD/CMDModeling_weighted_Delaunay_CGAL_2D.h:95:
instantiated from here
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:1787:
error: 'class
CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_with_info_2<int,
>, CGAL::Triangulation_ds_face_base_2<void> > > > > > >'
has no member named 'is_hidden'
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:1788:
error: 'class
has no member named 'set_hidden'
In member function 'bool CGAL::Regular_triangulation_2<Gt,
Tds>::Hidden_tester::operator()(const typename
Tds>::Finite_vertices_iterator&) [with Gt =
> >, Tds =
/storage/usr/people/400555/CGAL-3.4/include/CGAL/iterator.h:510:
instantiated from 'CGAL::Filter_iterator<I,
P>::Filter_iterator(I, const P&, I) [with I =
CGAL::Triangulation_2<CGAL::Weighted_point_mapper_2<CGAL::Regular_triangulation_filtered_traits_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>::Finite_vertices_iterator, P =
CGAL::Regular_triangulation_2<CGAL::Regular_triangulation_filtered_traits_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>::Hidden_tester]'
/storage/usr/people/400555/CGAL-3.4/include/CGAL/iterator.h:556:
instantiated from 'CGAL::Filter_iterator<I, P>
CGAL::filter_iterator(I, const P&, I) [with I =
>::Hidden_tester]'
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:1994:
Tds>::finite_vertices_begin() const [with Gt =
> >, Tds =
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:2003:
CGAL::Regular_triangulation_2<Gt, Tds>::finite_vertex()
const [with Gt =
> >, Tds =
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:1066:
> >, Tds =
> >, Tds =
/storage/usr/people/400555/CGAL-3.4/include/CGAL/Regular_triangulation_2.h:105:
error: 'class
make[2]: *** [CMakeFiles/main.dir/main.o] Error 1
On Tue, Aug 11, 2009 at 7:54 PM, Manuel Caroli
<mailto:>
<mailto:
<mailto:>>>
wrote:
400555 wrote:
Hello everyone !
Is it possible to have weighted Delaunay
triangulation with
info with using CGAL ?
And am I correct that CGAL regular triangulation of a
set of
weighted points gives me weighted Delaunay ? ...but
how to add
info to it, I don't know
sorry I forgot: yes, the CGAL regular triangulations
correspond to
weighted Delaunay triangulations.
Can you help me, please?
Thank you.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Regular triangulation with info, 400555, 08/11/2009
- Re: [cgal-discuss] Regular triangulation with info, Manuel Caroli, 08/11/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/12/2009
- Re: [cgal-discuss] Regular triangulation with info, Sebastien Loriot, 08/12/2009
- Re: [cgal-discuss] Regular triangulation with info, Manuel Caroli, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, Sylvain Pion, 08/13/2009
- [cgal-discuss] Delaunay triangulation 3, Sebastien Loriot, 08/13/2009
- Re: [cgal-discuss] Delaunay triangulation 3, Sebastien Loriot, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/17/2009
- Re: [cgal-discuss] Regular triangulation with info, Andreas Fabri, 08/17/2009
- Re: [cgal-discuss] Regular triangulation with info, Vitaliy, 08/17/2009
- Re: [cgal-discuss] Regular triangulation with info, Vitaliy, 08/19/2009
