- To:
- Subject: Re: [cgal-discuss] facet iterator
- Date: Thu, 13 Aug 2009 18:33:04 +0200
Dear Michal,
I suggest you have a more in-depth look at the documentation of the 3D triangulation package and the 3D triangulation data structure package.
I will try to give you some short hints, but I cannot repeat the whole documentation.
wrote:
Hi,Facets are the 2-simplices (triangles) that are contained in the triangulation.
I have a question. What does it means facet in 3D triangulation? For
example, consider the cell (a,b,c,d) of the triangulation. Contains theIf you are talking of a triangulation of the points a, b, c, and d yes. But there are also infinite facets (see documentation). Note that facets are only represented implicitly, i.e. as a Cell_handle and an index (see documentation).
triangluation following facets only? :
I don't understand this.
a,b,c
a,b,d
a,d,c
b,d,c
Or are there two facets for each side of each triangle? :
It iterates through all the facets of the triangulation visiting each facet exactly once. (see doc).
a,b,c
c,b,a
a,b,d
b,b,a
a,d,c
c,d,a
b,d,c
c,d,d
Which kind will give me following code? :
If you are given three vertices you can use the function is_facet to get one of the cells it is incident to. You can get the other cell using the neighboring relation.
for (Dh::Facet_iterator it = T.facets_begin(); it != T.facets_end(); ++it)
I have another question too. How can I determine incident cells of the
facet denoted by thee vertex handels?
best
Manuel
- [cgal-discuss] facet iterator, michal, 08/13/2009
- Re: [cgal-discuss] facet iterator, Manuel Caroli, 08/13/2009
- Re: [cgal-discuss] facet iterator, michal, 08/13/2009
