- To:
- Subject: Re: [cgal-discuss] facet iterator
- Date: Thu, 13 Aug 2009 18:54:26 +0200 (CEST)
- Importance: Normal
Dear Manuel,
thanks a lot. I'll look at the documentation better.
Michal
> Dear Michal,
> I suggest you have a more in-depth look at the documentation of the 3D
> triangulation package and the 3D triangulation data structure package.
> I will try to give you some short hints, but I cannot repeat the whole
> documentation.
> wrote:
>> Hi,
>> I have a question. What does it means facet in 3D triangulation? For
> Facets are the 2-simplices (triangles) that are contained in the
> triangulation.
>> example, consider the cell (a,b,c,d) of the triangulation. Contains the
>> triangluation following facets only? :
> If you are talking of a triangulation of the points a, b, c, and d yes.
> But there are also infinite facets (see documentation). Note that facets
> are only represented implicitly, i.e. as a Cell_handle and an index (see
> documentation).
>> a,b,c
>> a,b,d
>> a,d,c
>> b,d,c
>> Or are there two facets for each side of each triangle? :
> I don't understand this.
>> a,b,c
>> c,b,a
>> a,b,d
>> b,b,a
>> a,d,c
>> c,d,a
>> b,d,c
>> c,d,d
>> Which kind will give me following code? :
> It iterates through all the facets of the triangulation visiting each
> facet exactly once. (see doc).
>> for (Dh::Facet_iterator it = T.facets_begin(); it != T.facets_end();
>> ++it)
>> I have another question too. How can I determine incident cells of the
>> facet denoted by thee vertex handels?
> If you are given three vertices you can use the function is_facet to get
> one of the cells it is incident to. You can get the other cell using the
> neighboring relation.
> best
> Manuel
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] facet iterator, michal, 08/13/2009
- Re: [cgal-discuss] facet iterator, Manuel Caroli, 08/13/2009
- Re: [cgal-discuss] facet iterator, michal, 08/13/2009
