- To:
- Subject: Re: [cgal-discuss] Uneven implicit surface result
- Date: Fri, 14 Aug 2009 15:27:32 +0200
- Organization: INRIA
hi Graham, have your tried tuning the third parameter if the surface? the relative precision of the dichotomy mechanism to find the intersection? Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 Graham Macpherson a écrit : Hello, I'm meshing surfaces using the implicit surface mesher and testing it with simple smooth shapes. Using the example examples/Surface_mesher/mesh_an_implicit_function.cpp I've created a fairly fine surface of a sphere using the criteria: 30.0, // angular bound 0.01, // radius bound 0.001 // distance bound The surface is not smooth - it has an "orange peel" look. Plotting the radius of each vertex of the triangulation shows the magnitude of error of the triangulation point positions from the expected radius of 1: fineSphereSurfaceWithRadius.png Creating a coarse surface with criteria 30.0, // angular bound 0.1, // radius bound 0.1 // distance bound Results in: coarseSphereSurfaceWithRadius.png where the magnitude of vertex error is similar, but in the fine case, the same radial vertex position error in a smaller triangle creates a bigger error in the normal direction, hence the uneven look. Is this the result that is expected? and is there anything that I can do to improve the conformance of the triangulation points to the expected sphere function? Am I missing a tolerance adjustment somewhere? It isn't a write precision/truncation problem, as I've set the precision of the ofstream to 15. Thanks, Graham |
- [cgal-discuss] Uneven implicit surface result, Graham Macpherson, 08/14/2009
- Re: [cgal-discuss] Uneven implicit surface result, Pierre Alliez, 08/14/2009
- Re: [cgal-discuss] Uneven implicit surface result, Graham Macpherson, 08/17/2009
- Re: [cgal-discuss] Uneven implicit surface result, Mariette Yvinec, 08/18/2009
- Re: [cgal-discuss] Uneven implicit surface result, Graham Macpherson, 08/18/2009
